Belt is walking off Cam gear why???
Old Nov 27, 2004 | 12:15 PM
CivicSiRracer69's Avatar
Default Belt is walking off Cam gear why???
I have a Z6 And I just started the motor for the first time today, and the belt is walking off the cam gear??? There also isn't a Crank pulley on the car yet so, im thinking maybe that holds it on??? and stops it from walking ??
Old Nov 27, 2004 | 12:30 PM
EK k kay's Avatar
Default Re: Belt is walking off Cam gear why??? (CivicSiRracer69)
You're running a car without a crank pulley...okay
Old Nov 27, 2004 | 12:34 PM
tRex99's Avatar
So u must just be running it on the battery? well i could see how it might hold it on but thats down low. U have it walking up top. Well tighten up the tensioner or get a new belt.
Old Nov 27, 2004 | 12:42 PM
EGinNY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiRracer69 &raquo;</TD></TR><TR><TD CLASS="quote">I have a Z6 And I just started the motor for the first time today, and the belt is walking off the cam gear??? There also isn't a Crank pulley on the car yet so, im thinking maybe that holds it on??? and stops it from walking ?? </TD></TR></TABLE>
im lost......
How is the belt even on then???
Old Nov 27, 2004 | 12:47 PM
eJone powereD's Avatar
Default Re: Belt is walking off Cam gear why??? (EGinNY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGinNY &raquo;</TD></TR><TR><TD CLASS="quote">
im lost......
How is the belt even on then???</TD></TR></TABLE>
lol thats what i was thinking too
Old Nov 27, 2004 | 12:51 PM
unknown0001's Avatar
Somebody change his title to "H-T's biggest idiot"
Old Nov 27, 2004 | 01:18 PM
GTlvr82's Avatar
Default Re: Belt is walking off Cam gear why??? (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">
Somebody change his title to "H-T's biggest idiot" </TD></TR></TABLE>
We already have one of those on this site......
Old Nov 27, 2004 | 01:20 PM
deleriumDC5's Avatar
Default Re: Belt is walking off Cam gear why??? (GTlvr82)
haha you guys are too funny
Old Nov 27, 2004 | 01:41 PM
Forward Motion's Avatar
Default Re: Belt is walking off Cam gear why??? (deleriumDC5-S)
i think what he ment was that hes using the stock crank pully and that the belt is moving on the cam gear side ways off the Cam gear itself. ive seen this happen before. I suggest rplacing the belt and the tensioner. This had solved the problem for me before.
If you have a fair amount of milage you may want to replace the water pump while you have it torn down that far. You'll find yourself pretty angry to go thru all that and find the water pump needed to be changed shortly afterward.
Old Nov 27, 2004 | 05:33 PM
Calvinator's Avatar
Default Re: Belt is walking off Cam gear why??? (Forward Motion)
Check the tensioner spring and retension your belt so its tight.
Old Nov 27, 2004 | 05:50 PM
99blackcivicSi's Avatar
Default Re: Belt is walking off Cam gear why??? (xtremeazian)
WOW!!!!! this thread is full of dumb *** people
the belt is probably walking off the gear because you don't have the bottom belt guide on or its moving around to much.
i threw one of my motors together too fast and i went out for a night of fun and illegal activities on the street and the belt kept trying to walk off, i had to stop a lot and push the belt back on the gears, i forgot to put on the bottom belt guide.
Try that first if the belt guide is on and isn't moving around a lot, put a new t-belt, tensionor, and water pump on it. PM me if you have anymore questions
Old Nov 27, 2004 | 06:00 PM
SICKSOLSI's Avatar
Default Re: Belt is walking off Cam gear why??? (99blackcivicSi)
you guys are all morons its the keyway for the crankpulley thats makin it walk off...i'll bet $1000...happened to me once
b18bEG's Avatar
i had that happen on mine, but i did havea crany pulley though, the tensioner is most likely shot.. replace it and you should be alright.
Old Nov 27, 2004 | 06:05 PM
SICKSOLSI's Avatar
Default Re: (b18bEG)
you need to have the crank pulley on along with the keyway for the belt to not walk...........
DumpdEJ6
Sep 12, 2010 08:05 AM
Swansen
15
Apr 1, 2009 02:39 PM
jdmpassword562
Jul 17, 2008 10:00 PM
all-mtr-teg
Jan 9, 2007 09:25 PM
JRciv
Nov 22, 2004 01:58 PM
