alignment problems after lowering
Old Nov 27, 2004 | 10:17 AM
projectej8's Avatar
Default alignment problems after lowering
i lowered my car yestrerday about 2.5-3 inches and the steering is off and goes to the right. Is this normal after lowering a car? Im pretty sure i had the coils at the same level, but could that be the problem? I know an alignment job is needed after a drop, how soon should i do it? Thanks in advance
Old Nov 27, 2004 | 10:57 AM
Feriofan's Avatar
Default Re: alignment problems after lowering (projectej8)
Yes after lowering the car you have to get an alignment, especially with that drop I will even say that you need a camber correction kit.
And if you have expensive or really soft tires do it ASAP b/c it will eat the tires very fast. I had that problem with my car and my Toyo tires were gone in 3 months.
Old Nov 27, 2004 | 12:12 PM
jayare05's Avatar
Default Re: alignment problems after lowering (Feriofan)
yes an alignment is a must.. anytime u ever mess with ur front end suspension u should get an alignment
mikbik
13
Aug 28, 2015 03:03 AM
Accord-Guy
Suspension & Brakes
10
Apr 20, 2008 08:54 PM
sidoe
Suspension & Brakes
10
Mar 1, 2008 06:13 AM
b16a2EBP
May 8, 2006 12:47 AM
99DXcoupe
Sep 27, 2002 09:35 PM
