2000 Si B16A2 Head on 97 ITR B18C5 Block?
if you dont mind me asking, why? did you obtain a C5 block with no head? juss curious. It is a bolt on, but i dont know of anyone whose done it, both heads are pr3 castings, just the "r" has a mild port, slightly better valvetrain and cams. I guess i'm curious to see if anyone has done this and actually improved on performance and what advantages this may have, b/c i dont see any.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revhard92si »</TD></TR><TR><TD CLASS="quote">Yes, it's been done. You will gain more torque and hp.</TD></TR></TABLE>
you've sparked my interest, what is the cause of the hp and tq increases?
you have anything that backs up this information? because for your information a pr3 head is the same that comes on the itr motors. The only idfference is the fact that the cams and the slight sand paper port job, etc, and the bigger intake manifold and tb setup found on the ITR heads.
You gain "can" gain more witha gsr head with the same stuff as the itr head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97dxswap »</TD></TR><TR><TD CLASS="quote">How do you think if will perform with a b16 tranny?
I have a friend that will sell me his TYPE R Block. by the way</TD></TR></TABLE>all in all you are just getting a cheap itr motor. b16 having the same gears as the itr trannywith no lsd and not for the glorified peg leg price. it will work fine. Go for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97dxswap »</TD></TR><TR><TD CLASS="quote">Nevermind it turned out to be a B18C1 not a 5
WA WA WA WA
I have a c5 block for sale for the right price if you want it. jerry built itr block with all new bearing and ctr pistons. I clocked a 13.1 with the block on gsr head.
I also am selling my whole engine. if your interested just thought I would give you first dibs.
WA WA WA WA
</TD></TR></TABLE>I have a c5 block for sale for the right price if you want it. jerry built itr block with all new bearing and ctr pistons. I clocked a 13.1 with the block on gsr head.
WA WA WA WA
I don't see what the big deal is..the block are the same anyway. Just build it up with some better parts. The C5 block has a heavier crank and slightly better rods and higher compression pistons, but its not like night and day.
WA WA WA WA
</TD></TR></TABLE>I don't see what the big deal is..the block are the same anyway. Just build it up with some better parts. The C5 block has a heavier crank and slightly better rods and higher compression pistons, but its not like night and day.
you are a mormon
you are a mormon
