car will not rev to red line
I have a 92 si with 188k and it will only rev to 6000 rpm. It acts like it is hitting a rev limiter at that point.
What is the correct gap for the spark plugs on this car?
Any suggestions where I can find a user manual with the car (e bay purchase without documentation) or a good repair manual you can suggest?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silvabullet »</TD></TR><TR><TD CLASS="quote">yea most likely its either ur tach or ecu.. my car did the same .. but it was my tach.. try changing that out first. then ur ecu.</TD></TR></TABLE>
It's a lot easier and cheaper to check out the ecu before you go trying to change out your tach...
hey my car has the same problem i was taking heading out to work when all of a suddent my car wouldnt rev higher than 6000 rpms and my check engine light came on, has this happen to you, tell me what you did to correct this problem....thanx
slammedz6ef
16
Aug 26, 2008 10:23 AM
