What can i use for a gasket
Old Nov 27, 2004 | 06:37 AM
DAVE15401's Avatar
Default What can i use for a gasket
I got a tanabe used catback exhaust for my car which is a 93 civic ex and the guy didnt send me any gaskets with it so what could i use since no muffler shop around here makes gasket and the pipe is 2.25 thanks for the help everyone
Old Nov 27, 2004 | 06:38 AM
mildly.interesting's Avatar
NAPA has gasket material on a roll, be an artist and cut it out...
Old Nov 27, 2004 | 08:10 AM
DAVE15401's Avatar
Default Re: (mildly interesting)
nope i called they dont carry it for exhaust just paper and cork on a roll i found its make a gasket copper with silicone heat up to 750 degrees would that work?
Old Nov 27, 2004 | 08:22 AM
right on
Old Nov 27, 2004 | 08:45 AM
Triscuit's Avatar
what about gasket sealer from your local autoparts store? my bad I didnt see it was for an exhaust, try to tighten as much with a power gun or rachet.
Old Nov 27, 2004 | 08:58 AM
stormy's Avatar
Default Re: (Ronin EG6)
what about calling tanabe usa
here http://www.tanabe-usa.com/ or it has to be either a 2 or 3 bolt flange so order them here http://www.kteller.com/store/p...9b6cc
Old Nov 27, 2004 | 09:19 AM
aldotyper's Avatar
Default Re: What can i use for a gasket (DAVE15401)
go to autozone and ask them to sell you the aluminum gasket. It is a small sheet you will have to cut out. the sheet looks aluminum foil paper but thicker and it has little pin holes all around. Use that it will work
Old Nov 27, 2004 | 09:34 AM
92 CIVIC HATCH VX's Avatar
Default Re: What can i use for a gasket (aldotyper)
They have liquid gasket at autozone??? that should work
Old Nov 27, 2004 | 10:46 AM
DAVE15401's Avatar
Default Re: What can i use for a gasket (92 CIVIC HATCH VX)
Thanks eveeryone for the help
3s1k
Jun 1, 2011 04:36 PM
swappedcx
Jul 30, 2006 03:00 PM
ITR43
Nov 23, 2004 09:07 PM
wizzards581
Feb 22, 2003 07:45 PM
