catalytic converter emptying
Old Nov 27, 2004 | 03:44 AM
RACEPAK's Avatar
Default catalytic converter emptying
hello everybody
i want to clean empty my catalytic converter.... at the last few moths i have a wired smell whan i park the car, i think its a burnt cat.
am i gonna have a poor low rpm idle if ill empty it?
best regards moshik galimidi
Old Nov 27, 2004 | 06:01 AM
Frozen E's Avatar
H-T White Ops
If you're going to do all that why not just weld a straight piece of pipe in it's place. I hope you don't have an OBD2 car because you're going to be throwing codes if you do that. If you think your cat is clogged, just get a new one.
Old Nov 27, 2004 | 07:15 AM
Si Shane's Avatar
Default Re: (IslandSi)
Buy X length of piping from kteller. (definitly not a plug, never done buisness w/ them either, just an easy name. Get x lenght of piping from whoever you want ) where X equals the length of a stock cat.
Order two flanges, matching the triangle and opposite end of the cat.
Go to a muffler shop, and ask them to weld the flanges onto the pipe, so it fits where your cat goes.
Then now, you have a 'test pipe' for not too much cash. Less work than clearing out your stock cat... and you still have a cat for smogging.
Modified by Si Shane at 8:52 AM 11/27/2004
Old Nov 27, 2004 | 07:38 AM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">If you're going to do all that why not just weld a straight piece of pipe in it's place. I hope you don't have an OBD2 car because you're going to be throwing codes if you do that. If you think your cat is clogged, just get a new one.</TD></TR></TABLE>
MY car is ODBII and not only do I not have a cat at all or a test pipe, my O2 is hanging in my engine bay. No CEL
Old Nov 27, 2004 | 07:47 AM
Luserkid's Avatar
Default Re: (specv5150)
Get a new cat. Your in cali, you have smog.
Old Nov 27, 2004 | 07:57 AM
f1z1c's Avatar
Default Re: catalytic converter emptying (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">hello everybody
best regards moshik galimidi</TD></TR></TABLE>
Get a new one installed. Californians shalt not fu* with thy cat. There are laws...
Old Nov 27, 2004 | 08:27 AM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">MY car is ODBII and not only do I not have a cat at all or a test pipe, my O2 is hanging in my engine bay. No CEL</TD></TR></TABLE>
Something's not right. You should be throwing a code in a hurry.
Old Nov 27, 2004 | 08:48 AM
stormy's Avatar
Default Re: catalytic converter emptying (f1z1c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1z1c &raquo;</TD></TR><TR><TD CLASS="quote">
Get a new one installed. Californians shalt not fu* with thy cat. There are laws...</TD></TR></TABLE>
no man 6 months in jail and a 5000 dollar fine plus your car most likely going to auction is sooooooo worth +1 hp
Old Nov 27, 2004 | 09:05 AM
green-'s Avatar
So your running open header? Im confused. You should be throwing a CEL.
Old Nov 27, 2004 | 12:06 PM
RACEPAK's Avatar
Default Re: catalytic converter emptying (sans)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sans &raquo;</TD></TR><TR><TD CLASS="quote">
omg are you serius?
i dont live in ca i live in israel. my uncle live there and that is my shipping address.
i cant use a test pipe in my country we dont have the sniffer test, just visual to check there is a cat.
am i gonna have a poor low rpm idle?
Old Nov 27, 2004 | 01:13 PM
specv5150's Avatar
Default Re: (green00EX)
My HX came with the car built into the header and the HEader I currently have isnt built like that. So my primary O2 is plugged in the header but my 2ndary isnt. Isntt the 2ndary O2 on OBDII located in the cat??
Old Nov 27, 2004 | 01:18 PM
eg6style's Avatar
well correctly me if im wrong but your second o2 is located on the bottom part of the header cause the header is actual your cat...so the first o2 is at the top and at the bottom of the big round cat is the other o2.
Boostage
Jul 1, 2005 11:20 AM
SIK IN DA HED
Jan 2, 2003 01:02 PM
KooK
Jun 25, 2002 10:03 PM
ezark
Jun 21, 2002 10:12 AM
LillDragun
Apr 23, 2002 09:49 AM
