$1700 worth it?!?!
Old Dec 29, 2001 | 09:46 PM
EliteIntegra's Avatar
Default $1700 worth it?!?!
a used type R tranny, lightened flywheel and racing clutch for 1700 canadian.....
how much difference is my car with the type R tranny anyways?
Old Dec 29, 2001 | 10:39 PM
Vazquez911's Avatar
Default Re: $1700 worth it?!?! (EliteIntegra)
If the LSD is with it... YES, otherwise... IM me, and I'd like to get this piece myself.
Old Dec 29, 2001 | 10:40 PM
StinkyTofu's Avatar
1st gear is the same, but all the rest i believe are shorter so you can land in higher rpms.
I have a question for you guys though. Vtec in our GSR's engages at 4400 rpms. i know that for a fact. How come people say you can't land in vtec in between shifts on a GSR tranny? I haven't pushed my car hard lately, so i can't tell but from what i remember i land around 6000 (i think a little below). That is well above 4400 rpms, which means i'm still in vtec. Are people talking about when the secondary butterflies open in the intake manifold? I'm a little confused.
Old Dec 29, 2001 | 11:25 PM
MachAF's Avatar
Default Re: $1700 worth it?!?! (B-18C1)
The higher lift and duration cam lobes engauges at high 4000's or low 5000's I believe, which you cannot notice at all, one time I was able to hear the pin clicking.
Then at 5750 the secondary intake runner in the intake manifold opens up, thats what you acutaly notice. You can't feel anything, you just hear the pitch of the engine change. Usually you when shift at 8100 in a GSR you drop out of the secondary intake runner stage by a few hundred rpms, with a type R you redline at 8300 and stay in the secondary intake runner stage.
Old Dec 30, 2001 | 12:32 AM
StinkyTofu's Avatar
Default Re: $1700 worth it?!?! (machaf)
So if you can't feel anything...then it doesnt matter? Its just the sound then.
And also, type R's don't have secondary intake runners since their intake manifold are single runners.
Old Dec 30, 2001 | 05:41 AM
1fastGSR's Avatar
New User
sound like a good deal. The ITR tranny would make more difference than i/h/e, IMO. The LSD will also help in the turns.
Old Dec 31, 2001 | 03:32 PM
Default Re: $1700 worth it?!?! (1fastGSR)
what is the lsd for anyways i need to know by wed though with the response... i need to know what im buying!! thanx
Old Dec 31, 2001 | 09:17 PM
Calavera's Avatar
LSD = Limited Slip differential ?
I dunno.
Old Dec 31, 2001 | 10:40 PM
2005 TSX's Avatar
Default B-18C1
I have a question for you guys though. VTEC in our GS-R's engages at 4400 rpms. i know that for a fact. How come people say you can't land in VTEC in between shifts on a GS-R tranny?
I can stay in VTEC in all gears on my GS-R, no problem. I "accidently" gave my brother a demonstration the other night.
Old Jan 1, 2002 | 02:49 AM
leechungsr's Avatar
well, basically, it biases the power going to the wheels to the wheel with the most traction. In turns, it would allow the outside wheel to turn faster (does that make sense).
im sure others can ellaborate on that. if you have Gran Turismo2 at home, you can read about the different kinds of LSDs..heh heh
but yea, 1700 is a VERY good deal
Old Jan 1, 2002 | 12:06 PM
MattG's Avatar
New User
That seems like a good deal. If you can swing it I would swap the taller GSR 5th gear though. Also consider your GSR tranny is worth a few dollars.
Old Jan 1, 2002 | 12:38 PM
under_psi's Avatar
Default Re: $1700 worth it?!?! (MattG)
if you're interrested in getting rid of your GSR tranny, consider it sold...
---> hybridteg@hotmail.com
Old Jan 1, 2002 | 09:50 PM
threatcon13's Avatar
New User
Default Re: $1700 worth it?!?! (T.O.tegs)
lsd also helps distribute the power to both wheels more evenly ( if u ever watch people at the strip when they launch alot of times only one wheel will start spinning) an LSD should help get both of the wheels spinning from what I know. (which isnt alot but oh well)
ek souljah
Oct 18, 2010 06:27 AM
espm1000
17
Sep 16, 2006 08:44 AM
SiR Inspired ED7
Apr 18, 2006 02:01 AM
MI4$DC5
May 19, 2005 09:25 PM
flashgsr
Nov 1, 2002 03:19 AM
