Front brakes
Old Nov 26, 2004 | 05:52 PM
jagged4698's Avatar
Default Front brakes
ok i have the front steering knuckle removed from the car. I have the 4 back bolts off and the 4 front bolts off the hub. the rotor and the hub spin seperately. I need to know how to get the hub off the rotor.... Do i have to use a press or do i have some other option....? Help quick...
Old Nov 26, 2004 | 05:54 PM
fw190bvi's Avatar
Default Re: Front brakes (jagged4698)
press
Old Nov 26, 2004 | 05:56 PM
jagged4698's Avatar
Default Re: Front brakes (fw190bvi)
i'm not really sure where i can do that....any suggestions as to what kind of places would have a press?
Old Nov 28, 2004 | 12:31 PM
sinister2c's Avatar
get longer screws and tread them through the rear holes.
Old Nov 28, 2004 | 03:40 PM
JimmyzGarage's Avatar
You can rethread the bolts back in, but not all the way and gently tap with a hammer, or just spray some wd-40 around and let it soak through then tap around the bearing race to get the bearing assembly free of the knuckle. The only time I used a press was to separate the bearing from the hub to replace the bearing.
Old Nov 28, 2004 | 03:58 PM
jagged4698's Avatar
Default Re: Front brakes (JimmyzGarage)
i'm confused which bolts do i put back in and tap???? and this is to get the hub off the rotor?
Old Nov 28, 2004 | 04:44 PM
jagged4698's Avatar
bump need info asap
Old Nov 28, 2004 | 05:14 PM
jagged4698's Avatar
anyone
Old Nov 28, 2004 | 09:32 PM
madd's Avatar
everyone seems to be having a lot of trouble doing this, but when i did mine, the rotor came right off the bearing assembly. simply bumped it with a hammar.... *Shrug*
Old Nov 29, 2004 | 03:29 AM
TouringAccord's Avatar
H-T Order of Merit
I had the same problem when I went to do this on my 95 EX. I had the four bolts on the back of the knuckle removed thinking the hub/rotor/bearing assembly would come out of the knuckle but it was so rusted it wouldn't even move with an arbor press. A hydrolic press was needed to remove the bearing from the knuckle. So I just took it to a shop and had them press everything apart and back again with new parts for $25 a side, that was simply for labor only since I already had all the parts.
Old Nov 29, 2004 | 02:05 PM
smooth95's Avatar
me too eazy use the hammer
Old Nov 30, 2004 | 03:36 AM
H-T Order of Merit
Default Re: (smooth95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smooth95 &raquo;</TD></TR><TR><TD CLASS="quote">me too eazy use the hammer</TD></TR></TABLE>
Punctuation and full sentences are your friend.
mwr1964
Aug 23, 2010 06:02 AM
soon2bdropped
Apr 22, 2007 06:39 AM
jBj
Apr 17, 2007 12:54 PM
R-Lug
Suspension & Brakes
Dec 18, 2005 08:33 PM
TURBO
Jul 15, 2004 12:26 PM
