whats wrong with my baby
Old Nov 26, 2004 | 03:50 PM
00lude's Avatar
Default whats wrong with my baby
i was driving my car the other day and i parked it for about an hour. i came back out and started it up and it was chugging and sputtering real bad. i drove it up the stret to my house. the next day i started it up and it did the same thing so i got new plug wires new plugs and a new cap and rotor. it did nothing. the guy at the shop took all the plug wires off when it was running one by one and all but the # 1 cyllinder reacted, when he took the wire off the idol lowered and it ran like **** but when he took off the #1 wire the idol stayed the same. what could this be please help i need my baby back to normal
Old Nov 26, 2004 | 04:25 PM
monalisa overdrive's Avatar
Default Re: whats wrong with my baby (Chase)
check your pcv valve/hose
Old Nov 26, 2004 | 04:49 PM
LudeyKrus's Avatar
Default Re: whats wrong with my baby (monalisa overdrive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monalisa overdrive &raquo;</TD></TR><TR><TD CLASS="quote">check your pcv valve/hose</TD></TR></TABLE>
That shouldn't be able to cause any symptoms like the ones he described.
You pretty much replaced all the ignition components it could be. Go pull the #1 spark plug and stick the plug into the wire. Then touch the ground strap of the spark plug to a bare part of the spark plug or another grounding spot and see if the spark plug makes a bright blue spark. If it does, check the connector for the fuel injector. If it's secure, pull the fuel injector and see if it's working or if it's clogged.
lsvtechatchy
May 13, 2010 09:26 AM
mackadocious
14
Jul 3, 2008 01:08 AM
SIlent92EG
May 25, 2004 02:35 PM
af97civic
Mar 18, 2004 05:28 PM
ACRXGuy
Dec 27, 2003 08:01 AM
