Help!..Does anyone have a DIAGRAM for jdm dc2 side markers?
Old Nov 26, 2004 | 02:58 PM
TOP*SECRET's Avatar
Default Help!..Does anyone have a DIAGRAM for jdm dc2 side markers?
Planning to put on some side markers on my 99 integra but need a DIAGRAM someone please help ?
Old Nov 26, 2004 | 06:08 PM
TOP*SECRET's Avatar
Default Re: Help!..Does anyone have a DIAGRAM for jdm dc2 side markers? (JDMDC2909)
Need help ?? BUMP::
Old Nov 27, 2004 | 02:09 PM
Honissan's Avatar
Me too if it exists. Bump!
Old Nov 27, 2004 | 02:33 PM
drdisco69's Avatar
Default Re: (Honissan)
Splice it into the existing corner lens wiring. There's only 2 wires, power and ground, and it doesn't even matter if they're backwards. A diagram would be a little silly.
Old Dec 2, 2004 | 07:10 AM
dFreezy's Avatar
Default Re: (drdisco69)
courtesy of PatrickGSR94:
Old Dec 2, 2004 | 08:46 AM
. o 69 o .'s Avatar
Default Re: (dFreezy)
you turn signal will be 3 wire, they side marker is 2. take a test light to find out which wire in the turn signal is 12V when the lights are turned on. That wire should also show no power when the lights are turned off. Next establish the ground wire in the turn signal. that will be the ground for your side marker. The third and final wire should show blinking light when hookep up to the test light and the turn signal is activated. This is the other wire you need to hook up. if the side marker is not syncronized with your turn signal, but is blinking, reverse the 2 wires
Hope that helps
VtecHachi
Feb 12, 2007 01:00 PM
hatch96y7
36
Dec 18, 2006 09:49 PM
mike5809
Honda Motorcycles
Aug 21, 2006 12:03 PM
dohc_profile
Apr 21, 2006 09:17 PM
everafter
Jan 4, 2004 07:23 PM
