How do you remove the H emblem?
Old Nov 26, 2004 | 12:53 PM
UA6 BALLER STATUS's Avatar
Default How do you remove the H emblem?
I got a real quick simple question to ask you guys, Ive serached but nothing came up. How do I remove the H emblem in the rear??
Old Nov 26, 2004 | 01:10 PM
93vtec ATL's Avatar
Default Re: How do you remove the H emblem? (Type SH)
you can remove most badges with a credit card. Very carefully seperate the emblem from the paint, and then use any paint-safe solvent in small amount to get the remainder of the glue stick-um off. Goo-gone and similar products are sometimes ok in very small quanitites. I would stay away from razor blades as it is very easy to damage the paint when using them.
Old Nov 26, 2004 | 01:23 PM
aboh6leenz's Avatar
Default Re: How do you remove the H emblem? (93vtec ATL)
You can also use floss and floss it off. You should try floss first to get it somewhat loose then use the credit card.
Old Nov 26, 2004 | 01:32 PM
93vtec ATL's Avatar
Default Re: How do you remove the H emblem? (aboh6leenz)
Good advice
Old Nov 26, 2004 | 01:49 PM
matix's Avatar
I used fishing line. Then clay bar the sticky stuff off.
Old Nov 26, 2004 | 01:52 PM
Default Re: How do you remove the H emblem? (matix)
I heard to remove the H emblem, there is a nut and I know when you remove it there is going to be a hole there.
Old Nov 26, 2004 | 02:09 PM
digitalh3lix's Avatar
theres no nut there. but there will be holes. the front one has a metal clip that clips it on.. takes a lil bit to pop off rear ones just have 2 holes with like 3m double sided tape to hold it in place. credit card and some goo gone to clean it up. works perfect... goo gone would probaly be a better way to take it off than using claybar.
Old Nov 26, 2004 | 03:10 PM
spnbb2
Guest
Posts: n/a
crowbar
Old Nov 26, 2004 | 03:24 PM
Default Re: How do you remove the H emblem? (digitalh3lix)
Yeah it came off in two seconds with the credit card. Thanks alot guys.
Now all I have to do is take off the ugly prelude residue.
Old Nov 26, 2004 | 03:36 PM
aboh6leenz's Avatar
ohhh its a type R now haha j/p
Yeah i took my friends civic emblem off and it still has the residue kuz he's a lazy *** ****, beens been a good couple months. lol
Old Nov 26, 2004 | 06:37 PM
ralpheezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type SH &raquo;</TD></TR><TR><TD CLASS="quote">Yeah it came off in two seconds with the credit card. Thanks alot guys.
do you still have the prelude letters that you took off?
for some strange reason i want to put them on my 4th gen.
Old Nov 26, 2004 | 06:55 PM
Default Re: How do you remove the H emblem? (ralpheyizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralpheyizzle &raquo;</TD></TR><TR><TD CLASS="quote">
for some strange reason i want to put them on my 4th gen.</TD></TR></TABLE>
Yes I do.
Old Nov 26, 2004 | 08:46 PM
mgags7's Avatar
alright...ill admit it...im jacking the thread....but while we are on the emblem topic....does anyone have an extra 4th gen front bumper H?? im missing mine and its ugly....help me...
Old Nov 26, 2004 | 08:54 PM
Default Re: (mgags7)
Check the classifieds, then serach http://www.google.com. Or you can get some JDM red ones.
Old Nov 28, 2004 | 02:26 PM
crasyuba21's Avatar
spray wd40 and let it sit for a few minutes, then a credit card would easily slide it off
Old Nov 28, 2004 | 03:36 PM
Default Re: How do you remove the H emblem? (crasyuba21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crasyuba21 &raquo;</TD></TR><TR><TD CLASS="quote">spray wd40 and let it sit for a few minutes, then a credit card would easily slide it off</TD></TR></TABLE>
Thanks but try reading the whole thread before you post.
Old Nov 28, 2004 | 03:37 PM
ludermark's Avatar
for my badges
also i think it would look cleaner if you removed type sh and dohc vtec as well
Old Nov 28, 2004 | 05:00 PM
Default Re: How do you remove the H emblem? (ludermark)
How could I take off the glue?
Old Nov 29, 2004 | 01:38 AM
PreludeH22vtec's Avatar
Before you do any of this, here is the method by body shops all over the world.
GENTLY heat the badge with a hair dryer/heat gun.
take a credit card and slide between the badge and bodywork.
badge off (no paint damage)
let panel cool down and glue harden
then use what we call in the UK a toffee wheel to remove glue (it is a round thick orange disk to remove glue and coachlines/pinstripes from body panels and smeels like toffee/candy when you use it cost about £3/$2).
then wipe claen with a paint prep wipe NOT paint thinners.
then to fix the holes.
use some metal glue and stick a small coin/piece of metal on the inside of the hole.
then on the outside put a strip of masking tape over the holes and cust out the bage hole with a stanly blade.
mix up a small amount of body filler and smoth into the holes.
just a filler starts to go hard (cures) use the stanly blade to level the filler so that it is flush with the panel.
allow to harden then apply touch up paint to holes with a small modeling paint brush and romove masking tape.
job done
Old Nov 29, 2004 | 09:01 PM
kickinchicken's Avatar
Default Re: How do you remove the H emblem? (PreludeH22vtec)
You can you a hair drier as well. But if you have an apartment like me then you'd have to carry a line from your apartment to your car down the sidewalk.
And to get off glue use a rag and very little paint thinner. should come right off. Only do this if you've waxed your car within the last 8 months or there is a possibility your paint would fade. but only if you drenched the rag.
Old Nov 29, 2004 | 10:34 PM
LudaMan's Avatar
Look what I can do!
Default Re: How do you remove the H emblem? (h23sleeper)
my emblem fell off a week after i bought the car
Old Nov 30, 2004 | 12:08 AM
pawz`'s Avatar
Default Re: How do you remove the H emblem? (LudaMan)
dental floss + blow dryer (heat up the glue) + rag =
VTEC_PRODUCTION
Paint and Body
Aug 10, 2007 09:50 PM
HOUSTONb
Paint and Body
May 1, 2007 11:12 PM
iam7head
Sep 25, 2002 07:05 AM
Anderson
Sep 10, 2002 09:35 AM
IntegraZ
Apr 22, 2002 09:33 PM
