those of u who are fi and hate turbo lag.
who cares....i mean so wat if u have to wait till 4k rpm for the boost...i mean its much better than us NA guyz having to wait for 6k rpm just for sum vtec...which isn't as crazy as turbo....right?? hehe just had to get this out my mind....
can't wait to get boosted
i wish my turbo even started to make power at 4000
I dont know what turbo you guys are running, but I have a t3/t04b w/ a .48 a/r. anyway, i start making boost around 2500 or so. full by 3500. really doesn't seem that laggy to me. not like everyone always said it was gunna be??
yea, the fmax spools up quick especially in 2nd and 3rd gear where you get great power all the way to redline. 1st gear lags a little though. If you floor it you get full boost at about 4000 but then it screams to redline though especially if you set the vtec point up high like 5800. if you leave it where it is stock there is a big power dip at about 4800.
ive got the maxrev manifold a t3/t04e stage 3, .63 a/r, 57 trim turbine.. 2.5" straight downpipe and a apex'i silvia i/c on a b16a.. the problem is just that i ran out of money to build the motor so i can only run 8psi instead of the 20 that this setup is supposed to be using..
damn 20 psi.....i wouldve gone w/ 3in dp-piping... and your i/c may cause your lagging as well...ur only boosting 8....when u go higher the efficiency does too
gotta keep mah AC man, i live in houston so i had to go with 2.5" downpipe... i/c pipe is 2.25 in and 2.5 out. its not bad as long as i race people starting at 5000 rpm, only takes a half a second or so after i punch it to get full power
i have a .48ar t3/t4 on my sohc, i start spooling around 2500 and have full boost, around 10psi, by 3200-3500rpm.
Once vtec comes on in 1st gear the front tires just light up!! even on sticky tires and good pavement.
liam
[Modified by liam821, 4:53 PM 12/30/2001]
Once vtec comes on in 1st gear the front tires just light up!! even on sticky tires and good pavement.liam
turbo lag sucks dude. Just really sucks. Getting the right size turbo for your car is soo important. Why would you only want a turbo that performed only above 4500? I get full boost by 3200-3500...awesome low end power. I can go up any hill in 5th gear without downshifting. Pass anybody on the freeway..without ever downshifting. Just floor it and spool...power. Its just soo much more fun to drive.
Try driving around a mitsu eclipse turbo....then you will understand why a quick spooling turbo kicks ***.
liam
YES! Spooling fast is a big plus. That is why with my D16 I chose a T3 60 trim, with a .48 exhaust housing. I want to hit boost at about 2500 and hit full boost around 3300. If it is lower rpms, then great! Longer time in boost = more fun!!!!
liam
liam
street_ride14
Jun 21, 2008 09:27 PM
