Very high fluctuating idle. Need help!!
So I just installed my stock manifold back on replacing the Skunk 2. I fixed my previous bouncing idle problem by replacing the TB gasket, but I still have a high idle. Every time I touch the gas, the idle gets higher and stays there. It doesn't fluctuate, and keeps getting higher everytime I shift until it gets to about 3k, then it drops back to 1.5k and does the same thing over. WTF is going on?
Modified by Ti3d in at 6:32 PM 11/29/2004
Modified by Ti3d in at 6:33 PM 11/29/2004
i dont think its your manifold... That happened to me, i thought it was a vacuum leak, but it wasnt. It was my throttle body. check your throttle body, it might be fucked up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustrag »</TD></TR><TR><TD CLASS="quote">check your fast idle thermal valve....@!!</TD></TR></TABLE>
I have a 2000 GSR. There is no FITV from what I understand.
Cable isn't too tight, and it returns freely. This stuff was all working before, so I doubt that's the problem. Would it act like this if there was a leak at the IM flange?
IntegraType-R
11
Jan 20, 2008 11:23 PM
boiwitwhitehond
Apr 12, 2005 09:39 PM
