issue with swap
Old Nov 26, 2004 | 07:58 AM
shadowz's Avatar
Default issue with swap
The other day I swapped in a new motor, but ive been having this issue every time i hit vtec and after, I seem to have a coolant leak somewhere, it drips right on top of the downpipe and smokes thats how i know theres a leak, but once again only after vtec. Yes I have checked all my lines, for proper connection and loose connections, torn or ripped lines. And after i let my car sit for a while the coolant drip goes away. Headgasket is perfect too. Can anyone help me out ?
Old Nov 26, 2004 | 09:57 AM
ANR008's Avatar
check your water pump. the seal on the shaft will go bad causing it to drip alongisde the block and down towards the center of the motor where it will drip onto the exhaust.
this is why you wont see a puddle when parked.
Old Nov 26, 2004 | 02:03 PM
shadowz's Avatar
Default Re: (ANR008)
Thanks I checked, but that seal is still good, but i dont get any leak until i drive at constant higher speeds or vtec
Old Nov 27, 2004 | 11:47 PM
sicsixone's Avatar
Default Re: (shadowz)
what you need to do is warm the motor up and pressure test it.you can rent one from autozone.
jack the car up and look for the leak.
single_slam
Feb 3, 2014 01:22 PM
Tour991
Honda Civic (2001 - 2005)
Apr 16, 2013 07:11 PM
OMG B16
Aug 27, 2005 08:20 PM
Allstar
Feb 26, 2003 05:55 PM
