Bad springs or bad shocks?
Old Nov 26, 2004 | 05:29 AM
biglew's Avatar
Default Bad springs or bad shocks?
What are the symptoms of each and how do I tell the difference?
Old Nov 26, 2004 | 02:11 PM
sabotage7's Avatar
Default Re: Bad springs or bad shocks? (biglew)
well.....the springs control ride hieght and ride frequency (the measure of how many times your suspension will bounce up and down, measured in cycles per minute. Stiffer springs = higher frequency = harsher ride) and the shocks act as a damping force to keep the springs from constantly compressing and decompressing .....so, with that said, what is your problem that you're having?.....if your ride is really bouncy going down the road, its probably your shocks.
Modified by sabotage7 at 6:40 PM 11/26/2004
Old Nov 27, 2004 | 07:02 AM
biglew's Avatar
Default Re: Bad springs or bad shocks? (sabotage7)
I bottom out from time to time, last time I had the car jack stands I can pull up the wheel on one side much easier than the other side.
Lightning Lover.
Sep 2, 2003 02:55 PM
victor903
Feb 20, 2003 06:28 PM
slowman
Oct 27, 2002 10:09 AM
crxaddikt
Sep 6, 2002 05:41 AM
rodimus
Jun 29, 2002 11:57 PM
