DOOR AND KEY LOCK FROZEN
Old Nov 26, 2004 | 04:35 AM
90babyblue's Avatar
Default DOOR AND KEY LOCK FROZEN
Modified by 90babyblue at 4:46 PM 12/20/2004
Old Nov 26, 2004 | 05:11 AM
TOAB's Avatar
they make stupid little keychain things... thin piece of metal... a battery... it heats up... stick it in the lock.
personally ive never used one, but if its fairly warm out... like above 15 degrees i'll just get a cup of boiling water.
Old Nov 26, 2004 | 06:41 AM
EX-JAY's Avatar
Default Re: DOOR AND KEY LOCK FROZEN (90babyblue)
Here in Boston I use WD-40. It melts the ice nicely. Try to lube the locks once a week, this will prevent it from getting frozen.
Old Nov 26, 2004 | 08:45 AM
Stew Pidasso's Avatar
Default Re: DOOR AND KEY LOCK FROZEN (EX-JAY)
Use WD-40 once a week and they won't refreeze
Old Nov 26, 2004 | 10:04 AM
Filthy Focker!'s Avatar
Default Re: DOOR AND KEY LOCK FROZEN (Stew Pidasso)
If it is indeed the lock that is the problem. Heat up your key with a lighter or small torch and stick it into the lock.
If it is the linkage and such, then spray wd-40 on it any which way you can.
fs
Old Nov 26, 2004 | 10:09 AM
90babyblue's Avatar
thanks guys...the gf is pickin up some wd-40 and some of that lock de-icer ****.....i appreciate the help.....
Old Nov 26, 2004 | 04:35 PM
khunt0012's Avatar
Meat Robot Invisible
Default Re: DOOR AND KEY LOCK FROZEN (filthy_shovel)
Lock de-icer works just ****. Only problem is the one time I needed it, and it was in the car with all my tools and misc. eother **** .
Slade Exulis
Sep 23, 2018 04:53 PM
Willby24
Dec 18, 2008 05:25 AM
integra_si-vtec
Jul 5, 2007 11:22 AM
Inaniac
13
Jun 25, 2002 06:47 PM
