tie rod end bad?
Old Nov 26, 2004 | 12:54 AM
91teg's Avatar
Default tie rod end bad?
I took my car to a shop to get it aligned, the worker at the shop said i needed a tie rod end on the right side front, cause it was bad. I noticed the tire on the right pass side was wearing on the outside before i took it in for the alignment. After i found out it was bad, i switched tires and rims. I went from LS-webs to 14'' steelies. It now wears on the inside of the tire....? Anyone know where to get some cheap tie rod ends or what ever i need to fix it? I am not sure what is wrong. Thanks
Old Nov 26, 2004 | 04:34 AM
gsrboi80's Avatar
Default Re: tie rod end bad? (91teg)
tie rod ends are cheap man like 40 a piece
decode33
Honda CR-V & Element
Oct 22, 2011 11:06 PM
Whatislove
Honda Civic (2001 - 2005)
Oct 21, 2008 06:02 AM
yOnKiNaToR
May 17, 2005 11:46 AM
dip-set
Oct 15, 2004 04:26 PM
2camsaam
May 1, 2002 07:34 AM
