B16a Ver
Its the other way around, B16A 1st gen had cable and 160hp. B16A 2nd gen had hydro and 168-170hp. To answer your question the 2nd gen had a higher compresion pistons, 10.2(1st gen) and 10.4(2nd gen)
what is the differents between the head of a B16a version 1 (hydro trans) and the a B16a version 2 (cable trans)?
how do you get a extra 10hp from a version 1 B16a???
the compression is higher but you will not get ten horse power from the .2 difference. the sir 2 has a bigger throttle bodie, a better intake manifold, has a better ecu,has a better compression ratio, and has diferent cams and all of that will make up for the 10 hp not jus cr!!!! ( these modifications that are different between thw 1and 2 are very small just like .002 on the cam an d like 2mm on the throttle bodie etc)
oops, it is the other way around, my bad :D
so there is alot of little things that make the gen 2 b16a 10hp more, i'm asking this question cause, my friend is going to build a B20z vtec and he has a 1st gen B16a, he wants to know how to make his 1st gen b16a the same as the 2 gen b16a
hucoreyCRX
16
Apr 8, 2007 10:14 PM
aonick
May 12, 2002 04:17 AM
