S2000 oil filtered Integra's
Old Nov 25, 2004 | 10:13 PM
Ballade's Avatar
Default S2000 oil filtered Integra's
The small (Fram) filter has been with us for a while now, just wondering
how you guys are gett'n on with those S2000 filters?
Any info you might want to pass along.
Old Nov 25, 2004 | 10:41 PM
Beach Accord's Avatar
Default Re: S2000 oil filtered Integra's (Ballade)
i know i don't own an integra...but i have been using the s2000 filters on my accord for a while now.
after cutting open a couple of filters i found the pcx-004 to be of superior build\quality.
Old Nov 25, 2004 | 11:58 PM
SlipAngleX's Avatar
Old Nov 26, 2004 | 06:31 AM
Ballade's Avatar
Default Re: (SlipAngleX)
Anyone else
Old Nov 26, 2004 | 08:57 AM
HONDA RR's Avatar
i'am not sure but when i went to the dealer the other day and bought a filter for my honda it looked a lot smaller than the older oil filters. When i asked the parts guy if its the right filter, he told me that they make them smaller now, i guess its to used to decrease the oil fluctuation when vtec engages.
Old Nov 26, 2004 | 04:15 PM
Ballade's Avatar
Default Re: S2000 oil filtered Integra's (MITSUBA)
Bump
Old Nov 27, 2004 | 04:38 AM
90lsteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITSUBA &raquo;</TD></TR><TR><TD CLASS="quote">i'am not sure but when i went to the dealer the other day and bought a filter for my honda it looked a lot smaller than the older oil filters. When i asked the parts guy if its the right filter, he told me that they make them smaller now, i guess its to used to decrease the oil fluctuation when vtec engages. </TD></TR></TABLE>
It isn't to decrease oil fluctuation, it's because Honda was manufacturing 2 filters with the same size gasket,threaded opening, filtering media but with different casing sizes, so they cancelled the bigger one seeing as how the small filter will work on anything except an Insight and an S2000. At least that is what Honda told us when they discontinued shipping of the big filter.
Old Nov 27, 2004 | 06:59 AM
Ballade's Avatar
Default Re: S2000 oil filtered Integra's (90lsteg)
Anyone using them on their integra?
Old Nov 27, 2004 | 10:57 AM
LSvtec03's Avatar
i was using it on my integra, until my shock tower broke.
the s2k filter is made from a better filter element. i forget who makes it, but it's whomever used to make the filters before it was fram. the s2k are still made in japan, while the newer, smaller ones are made in canada, i believe.
Old Nov 27, 2004 | 12:03 PM
Default Re: S2000 oil filtered Integra's (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">i was using it on my integra, until my shock tower broke.
the s2k filter is made from a better filter element. i forget who makes it, but it's whomever used to make the filters before it was fram. the s2k are still made in japan, while the newer, smaller ones are made in canada, i believe.</TD></TR></TABLE>
toyo roki is whom you are referring to.....
Old Nov 27, 2004 | 12:19 PM
tremor86's Avatar
Filtech, fram, and toyo roki all manufacture honda filters.
Old Nov 27, 2004 | 12:41 PM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Default Re: S2000 oil filtered Integra's (tremor86)
Been running the S2k oil filter for the past 4 months, nothing but good things. I was skeptical but my car runs good. No problems, a very worthwhile piece considering it is only a dollar more. There is a considerable amount of difference in size in the S2K and GSR one.
Old Nov 27, 2004 | 01:01 PM
Ballade's Avatar
Default Re: S2000 oil filtered Integra's (JDMThoughts)
Just installed the S2000 oil filter on my 91 integra. I cut open the small (honeywell) filter which I removed. This is what I saw.
Plastic bypass valve attached to a what looks like a pop can bottom with a spring.
everything eles was cardboard.
Over all constuction looked very very cheap.
Old Nov 27, 2004 | 01:16 PM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ballade &raquo;</TD></TR><TR><TD CLASS="quote">Just installed the S2000 oil filter on my 91 integra. I cut open the small (honeywell) filter which I removed. This is what I saw.
Are you sure you bought an OEM Toyo Roki? Because ,Honeywell= Fram filters.
Old Nov 28, 2004 | 06:41 PM
Ballade's Avatar
Default Re: S2000 oil filtered Integra's (timmy8151)
Sorry, yes I installed the Toyo Roki and cut open the Fram / Honeywell peice of #%$!
SwedBoy2999
Honda S2000
Jan 2, 2010 06:23 PM
xintegr
Aug 29, 2007 06:46 AM
rohec04
Aug 7, 2007 10:11 AM
LSVTEC 91 Civic
Honda S2000
10
Apr 10, 2005 12:18 PM
