Hard Time Starting In Cold
Old Nov 25, 2004 | 08:31 PM
Kan's Avatar
Kan
Default Hard Time Starting In Cold
I have a 98 accord V6 with 175K and its having a hard time starting in cold weather. In warm and hot weather its fine, in cold it struggles to start but once it does it runs fine.
Any help would be greatly appreciated.
Thanks
Old Nov 25, 2004 | 09:16 PM
LiL accORd RideR's Avatar
Default Re: Hard Time Starting In Cold (Kan)
do u have any anti-freeze?
Old Nov 26, 2004 | 07:57 AM
Filthy Focker!'s Avatar
It could be a bunch of things from injectors, ecu, ignition, fuel, etc.....
How long does it need to be cranked before it starts?
Does black smoke come out the pipe when it starts?
Does it idle properly when you start it cold?
How long do you have to let it sit after it has run before the problem re-occurs?
fs
Old Nov 28, 2004 | 01:43 AM
tjohnson329's Avatar
your battery might be out of cold cranking amps likemine was and therefore the car is hard to start if starts at all. If it started fin in warm weather and not in cold, replace the battery.
Old Nov 30, 2004 | 01:51 PM
VTECsop's Avatar
try putting a thinner oil in the motor next time u change the oil. I'm assuming you're using a 20-50 if it has a lot of miles. run a 10-40 maybe
79powerwagon
16
Dec 27, 2010 09:25 PM
gerhard
Dec 7, 2007 03:00 PM
95goldSE
Sep 12, 2007 03:38 PM
vlc92189
Jan 30, 2007 04:53 AM
Bruce_Willis
Jan 4, 2005 08:33 AM
