90 integra obd0 to obd1 speedo
Old Nov 25, 2004 | 07:19 PM
04falcon's Avatar
Default 90 integra obd0 to obd1 speedo
I 'm converting mt 90 integra to obd1 from obd0.I know i need a obd1 ecu,dist and a 4 wire 02 sensor.Is there anything I need to do for the speedometer considering the obd0 is cable and the obd1 is electronic?
Old Nov 26, 2004 | 08:47 PM
strikeback03's Avatar
Default Re: 90 integra obd0 to obd1 speedo (04falcon)
92-93 Tegs are OBD 1 and still use a cable speedo. You will either need to use the cable speed sensor with your new setup or figure out how to use a 94+ speedometer with the electronic VSS.
94 ls-r
Jan 25, 2011 06:45 PM
SolAssassin
May 7, 2009 10:00 AM
CBURKE
Oct 11, 2005 06:41 PM
iNetForce
May 30, 2004 07:38 PM
