Awful Coolant Smell inside of car?.....
Old Nov 25, 2004 | 06:52 PM
1meangsr's Avatar
Default Awful Coolant Smell inside of car?.....
hey HT,
I have a 96' GSR w/ a b18c1 block, b16 head with a stock head gasket. Anyway I just developed this awful coolant smell in my car as of this afternoon....I searched a little bit and the other threads seem to indicate that it could be a head gasket. But I just have had this motor put together a little over a month ago...sooo I am going to rule that out at this point. I read in a couple of other places that a bad heater core could also cause this smell....is this true? Also my coolant reservoir was completely empty! Any help at all would be appreciated! Thanks in advance...
Old Nov 25, 2004 | 06:54 PM
No-Gi's Avatar
Default Re: Awful Coolant Smell inside of car?..... (1meangsr)
Its leaking somewhere, could be the heater core. Have you checked the oil to see if there is any coolant there?
Old Nov 25, 2004 | 06:59 PM
Beach Accord's Avatar
i would put my money on the heater core.....check the carpet\floorboard around that area (passenger side under dash)
Old Nov 26, 2004 | 02:45 AM
s2kkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1meangsr &raquo;</TD></TR><TR><TD CLASS="quote">hey HT,
I have a 96' GSR w/ a b18c1 block, b16 head with a stock head gasket. Anyway I just developed this awful coolant smell in my car as of this afternoon....I searched a little bit and the other threads seem to indicate that it could be a head gasket. But I just have had this motor put together a little over a month ago...sooo I am going to rule that out at this point. I read in a couple of other places that a bad heater core could also cause this smell....is this true? Also my coolant reservoir was completely empty! Any help at all would be appreciated! Thanks in advance...</TD></TR></TABLE>
Heater core....
I just did on on a vw passat and it kicked my *** had to pull the entire dash out of the car
Im putting all my money on the heater core. You might not even see coolant on the ground, it might be filling up in the evaporator box. Thats what the vw had, it was almost filled to the top, and it smelled bad of coolant inside.
Old Nov 26, 2004 | 08:39 AM
1meangsr's Avatar
Default Re: Awful Coolant Smell inside of car?..... (vtecluder97)
no coolant in the oil..... but yeah I figured as much (heater core).....how much of a pain in the *** is it to remove an integra dash? Does anybody have any instructions! LOL! Let me know.... Thanks a bunch for you folks that helped me out!
Old Nov 26, 2004 | 10:30 AM
DRIVENRacing's Avatar
Default Re: (Beach Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beach Accord &raquo;</TD></TR><TR><TD CLASS="quote">i would put my money on the heater core.....check the carpet\floorboard around that area (passenger side under dash)</TD></TR></TABLE>
the newer cars have a tube that if the heater core goes out it dumps under the car and NOT in the car. so let the car run and see if any coolant is under the car, it wont be in the inside. happend to me
Codielee2832
25
Oct 24, 2018 09:28 AM
1bar_ek
May 7, 2005 07:57 AM
EK9 BEEZLER
Apr 18, 2005 09:58 AM
JDMallTHEway
Dec 1, 2004 10:29 AM
