ECU pinouts B20/VTEC
Old Nov 25, 2004 | 05:16 PM
Pr0jektLude's Avatar
Default ECU pinouts B20/VTEC
What pinouts should i use, im using a b20a block with a gs-r head and ls tranny. I need the pinouts i would use when im using the gs-r ecu.
Old Nov 25, 2004 | 08:32 PM
krazie1's Avatar
BANNED
Default Re: ECU pinouts B20/VTEC (Pr0jektLude)
huh
this is a noobie question it all depends in ur set up
What car?? What harness??? What gen motor???
I would try searching next time
Old Nov 27, 2004 | 12:26 PM
Default Re: ECU pinouts B20/VTEC (krazie1)
im using a b20 block in a 90 prelude, with a gs-r head from a 94 g3 and i got the wiring harnees obd1 with a p72 ecu i got all the pinouts but "D12"- it says its a yel/grn wire but no description? what wire is this? And is the pinouts for a p72 obd1 goin to work for this setup?
Old Nov 27, 2004 | 02:26 PM
v4lu3s's Avatar
RTFM
well the pinouts are going to be the same for all p72 ecus regardless of what engine you have...so im not seeing what you are asking.
Old Nov 27, 2004 | 04:08 PM
bluebird's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr0jektLude &raquo;</TD></TR><TR><TD CLASS="quote">im using a b20 block in a 90 prelude, with a gs-r head from a 94 g3 and i got the wiring harnees obd1 with a p72 ecu i got all the pinouts but "D12"- it says its a yel/grn wire but no description? what wire is this? And is the pinouts for a p72 obd1 goin to work for this setup?</TD></TR></TABLE>
Are you attempting to use the b20a in the prelude with the vtec head?
Old Nov 28, 2004 | 02:03 PM
Default Re: ECU pinouts B20/VTEC (bluebird)
im not persay but a friend of mine is, yes all p72 ecu's are the same but what pinout is D12?
efjones9
Jan 4, 2013 11:10 AM
93redeghatch
Mar 24, 2010 11:43 AM
integra3586
Sep 21, 2009 02:08 PM
Honda_Fanatic
Nov 29, 2007 05:27 PM
ilovemyride
11
Jul 13, 2005 02:07 PM
