Hondata Q...
Old Nov 25, 2004 | 05:08 PM
^AnDre^'s Avatar
Default Hondata Q...
I dont want to sound like an idoit... but heres my case..
ive been fidiling around with engines and know a bit.. however i dont know everything ( and before you all decide to call me an idiot... at one point you guys didnt know anything either) ... I have picked up a b18c5 for my 89 civic dx and im gonna be fixin it up (the car is simply a lapping car right now.. not street legal)... and im gonna change stuff like (AEMS IM, Skunk 2 Cam & Cam Gears, Dual Valve Springs w/Titanium retainers, thinner head gasket to bump compression up, in tank fuel punp & pressure regulator.. and b16a ecu to minimilze errer codes).. however I hear all this talk about needing a hondata unit... ive looked up and tried to do all the research i could.. however.. what are the exact benefits of having one and is it even needed... (ive been told i need one to produce any gains out of the cams).... is this true... please help me out... i dont want to spend money where i dont have to seeing how im on a tight budget..
Old Nov 25, 2004 | 05:13 PM
Bbasso's Avatar
Default Re: Hondata Q... (^AnDre^)
When ever you can FINE TUNE the car to perform better you will have more and better results.
If your just using a simple tuning device such as VAFC you can only make minor adjustments but nothing in the detailed dept.
Hondata or AEM EMS should work just fine for you.
Old Nov 25, 2004 | 11:09 PM
Copy Cat's Avatar
Default Re: Hondata Q... (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">When ever you can FINE TUNE the car to perform better you will have more and better results.
Hondata or AEM EMS should work just fine for you.</TD></TR></TABLE>
civic j
May 30, 2008 03:23 PM
Raptastik87
22
Nov 23, 2007 05:40 PM
red civic standard
11
Aug 8, 2004 08:38 PM
RangerDan
Aug 12, 2003 11:55 PM
NCSTIdriver
Sep 12, 2002 07:04 AM
