Search is broken at the moment.. best clutch for turbo integra (street use)
Old Nov 25, 2004 | 04:31 PM
PanikAttack's Avatar
Default Search is broken at the moment.. best clutch for turbo integra (street use)
Anyone have any recommendations?
Old Nov 25, 2004 | 04:45 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Search is broken at the moment.. best clutch for turbo integra (PanikAttack)
How much power are you making?
How much do you want to spend?
Do you care about "driveability" meaning....do you care if it squeaks/chatters/has rough engagement?
Old Nov 25, 2004 | 07:06 PM
No-Gi's Avatar
Default Re: Search is broken at the moment.. best clutch for turbo integra (shamoo)
I had a clutchnet stage II on my turbo b16. No chatter at all. Held up nice to 14 PSI and helped me run 12.7's with 1.8 60' time.
Old Nov 26, 2004 | 02:11 PM
b18b integra.
See the restoration here http://www.optinplus.com/acura
10lbs of boost
Old Nov 26, 2004 | 02:54 PM
b18vtek's Avatar
Anything over 400hp stage 4, anything less stage 3 would be fine. If it's a drag/strip car stage 6.
Old Nov 26, 2004 | 04:33 PM
OneSloTeg's Avatar
Default Re: Search is broken at the moment.. best clutch for turbo integra (b18vtek)
The search is fine....Learn to use it
Old Nov 26, 2004 | 04:35 PM
Default Re: Search is broken at the moment.. best clutch for turbo integra (OneSloTeg)
Take your post count somewhere else dummy.
At the time i wrote the post the search was not working properly.
It was erroring out no matter what kind of input I gave it.
Old Nov 26, 2004 | 04:42 PM
OneSloTeg's Avatar
i used it not 1 min after you used it...and i had no problems at all
Old Nov 27, 2004 | 03:36 AM
oh yeah? well i used it 3 times since then and its worked fine!
Old Nov 30, 2004 | 09:31 PM
What do you guys think of this one?
Should i get this? recommendations please!?
http://cgi.ebay.com/ebaymotors...33730
bonesx0x2x4x
Transmission & Drivetrain
Feb 25, 2011 12:10 PM
HomeDepotMade
Jan 31, 2007 05:45 AM
alexsracing
Aug 1, 2005 11:45 AM
SwIntegraB16
15
Feb 12, 2005 07:43 PM
