ITR cluster into a 96-00 civic direct swap??
Will a obd2 JDM ITR cluster directly fit into a 96 00 civic ? No wire changes or fitting issues ? has been down for the past couple of hours. I would search but the search
thanks
thanks
No, its far from a direct swap. The cluster doesn't physically sit in the same way (not the same size nor shape) and the wiring is completely different.
and the black one is hot.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx »</TD></TR><TR><TD CLASS="quote">Get a 99-00 SI cluster. Its plug and play.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1053318
For the wiring. The 96-00 Plugs physically fit the ITR cluster. Just use the wiring diagrams in the link. 96 spec = 94-97 diagram and 98 spec = 98-01 diagram.
Nameless RB26
Dec 28, 2002 01:54 PM
