loose shifter
Old Nov 25, 2004 | 11:53 AM
rasta420's Avatar
Default loose shifter
when i have my shifter in gear and im jus cruising along, i can actually move the shifter side to side about 1/2'' to each side. i dont think its a bad bushing cuz i checked the bushings about a month ago...anyone have this problem and how did you fix it?
Old Nov 25, 2004 | 11:55 AM
messeduprex's Avatar
Default Re: loose shifter (rasta420)
i'm still trying to figure that one out also i've replaced all of my bushings with e. s. ones and went to a skunk shifter and it still does it
Old Nov 25, 2004 | 11:58 AM
tur3oDC4's Avatar
Default Re: loose shifter (messeduprex)
Dosent the boot that goes around the " ball " on the shifter alow for a little play side to side?
Old Nov 25, 2004 | 12:00 PM
Default Re: loose shifter (B18CRXjake)
i've benn in ef's that the shifter dosent move side to side at all and mine moves about 3/4 of aN INCH WHILE IN GEAR
Old Nov 25, 2004 | 12:07 PM
rasta420's Avatar
i was thinkin maybe bad engine mount, cuz my rear mount is pretty much nonexistant, but then again it moves while im jus cruising...
Old Nov 25, 2004 | 06:26 PM
SwissChEz82's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by messeduprex &raquo;</TD></TR><TR><TD CLASS="quote">i've benn in ef's that the shifter dosent move side to side at all and mine moves about 3/4 of aN INCH WHILE IN GEAR</TD></TR></TABLE>
bump for the same problem, I just thought it was the bushings, but guess not.
Old Nov 25, 2004 | 09:57 PM
LoSt is BlaCk's Avatar
Default Re: loose shifter (SwissChEz82)
it is related to the actaul linkage, those joints get loose...i am trying to figure out how to fix mine too
9818tegr
May 5, 2022 06:49 AM
Nooch
10
Aug 19, 2011 10:54 PM
jb0705
Jul 10, 2009 12:39 PM
blackhope121
Mar 21, 2007 06:33 AM
CTR-GSR
Feb 24, 2006 09:47 PM
