Clutch help!!!
Old Nov 25, 2004 | 09:46 AM
P R E L U D E's Avatar
Default Clutch help!!!
Last night my 93 vtec lude was driving fine. I got home...still fine. I go to drive her today and the clutch easily goes down and i cant get her in gear. The only thing i did diferent was i parked her on a hill. I dont know much about clutches and trannys so is there some clutch fluid that may be low. what do you guys think?
If it is clutch fluid; which reservoir is it?
Old Nov 25, 2004 | 10:22 AM
mgags7's Avatar
theres a small fluid reservoir on the driver side under the hood, right to the left of a bigger one(the brake master cyl).....that reservoir is for the clutch....check that....fill it up....but you have a leak somewhere.....you probably can get by by just pumping the clutch up and down for a few minutes, it will probably drive then.....check out the search, this has been covered a lot in the past...
Old Nov 25, 2004 | 04:45 PM
Pr3lude_98's Avatar
Default Re: Clutch help!!! (P R E L U D E)
Mine was doing the same thing. TUrned out to be the slave cylinder but got new clutch too because it was worn out.
Old Nov 25, 2004 | 05:55 PM
digitalh3lix's Avatar
yea, seems like the slave cylinder. mine did that too. but i ended up needin a new clutch too.
Old Nov 25, 2004 | 08:50 PM
monalisa overdrive's Avatar
Default Re: Clutch help!!! (digitalh3lix)
did it wear out cause the slave cyl. blew? or was it just about time to get a new clutch?
Old Nov 25, 2004 | 10:54 PM
Default Re: Clutch help!!! (monalisa overdrive)
it turned out to be that the reservoir was low on fluid.
brenden747
14
Apr 27, 2012 10:40 AM
06typeSEX
12
Jun 1, 2009 02:12 PM
AllMotorRP
Honda S2000
Mar 23, 2009 07:41 PM
evade_07
Dec 13, 2008 10:15 PM
eL
23
Sep 21, 2004 03:40 PM
