Stupid Question.. Are all B series engines the same size, just different boring?
I was looking for an oil pan for a b16a2 and i noticed they klump the b-series together when the advertise. Are parts like this universal? Also, do the heads of say a b16 bolt onto a b18 or b17 etc..? I'm starting to get confused now. I was thinking of buyin a b16a2 block and building it. So this is why i bring this up. Thank you.
Yea, most parts are interchangable. Heads and block are, for the most part. (Cant bolt a VTEC head on a non VTEC block without modification) but for about 95% of parts can be swapped back and forth.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honissan »</TD></TR><TR><TD CLASS="quote">are transmissions a whole new story? I will be building a b16 can I use my D16 tranny with a new clutch, seeing as how the blocks are displaced the same size?</TD></TR></TABLE>No you cant. Im guessing your car is a 92-00 civic. use any hydrolic transmission. gsr,b16,ls,type r,Si(99-00) all these will bolt right up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honissan »</TD></TR><TR><TD CLASS="quote">I was looking for an oil pan for a b16a2 and i noticed they klump the b-series together when the advertise. Are parts like this universal? Also, do the heads of say a b16 bolt onto a b18 or b17 etc..? I'm starting to get confused now. I was thinking of buyin a b16a2 block and building it. So this is why i bring this up. Thank you. </TD></TR></TABLE>
b16 oil pans are not interchangeable with b18c, but i heard they are interchangeable with b18a/b. b18c abd b16 head gaskets are the same, and i have one for sale if interested, brand new
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM96SpecCTR »</TD></TR><TR><TD CLASS="quote">
do what? all b series oil pans are the same
</TD></TR></TABLE>do what? all b series oil pans are the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic »</TD></TR><TR><TD CLASS="quote">
do what? all b series oil pans are the same</TD></TR></TABLE>
u sure about that? i heard different
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow94coupe »</TD></TR><TR><TD CLASS="quote">isnt the gsr different because of the girddle or sumthin?</TD></TR></TABLE>
yes
yes
the pans im 99.99% sure are the same. the oil pump and windage trays are in fact different.
must all the B series bottom ends have interchangeable Heads and Trans, exept for the old school (like 87 or so, the ones with AWS) Preludes. Those have B22's on them but they are not copatible with newer B series..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic »</TD></TR><TR><TD CLASS="quote">the pans im 99.99% sure are the same. the oil pump and windage trays are in fact different.</TD></TR></TABLE>
Actually you are wrong, the b18c oil pan IS different from the b16, because of the main gridle on the b18c. The b18c has p72 stamped on it too, where as the b16 doesn't, and it doesn't fit if you try to line it up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboxsi »</TD></TR><TR><TD CLASS="quote">
Actually you are wrong, the b18c oil pan IS different from the b16, because of the main gridle on the b18c. The b18c has p72 stamped on it too, where as the b16 doesn't, and it doesn't fit if you try to line it up. </TD></TR></TABLE>
thank you then
thank you then
b16 oil pans are not interchangeable with b18c, but i heard they are interchangeable with b18a/b. b18c abd b16 head gaskets are the same, and i have one for sale if interested, brand new </TD></TR></TABLE>
thank u also
thank u also
thank u also
thank you then </TD></TR></TABLE>
NP, I had to replace my b16's awhile back, so i did some research and that was what i found. Plus i tried fiting the b18c's oil pan to physically see that it doesn't fit.
thank u also
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic »</TD></TR><TR><TD CLASS="quote">
yea same for me, except i didnt actually try to fit it. i just researched.
i did however try to put a crx oil pan on a d16y7 and that didnt work either
davidcrx89
12
Jul 5, 2005 11:59 PM
