Should I be using teflon tape when connecting brake lines/components??
Old Nov 25, 2004 | 06:23 AM
WyteNyteGSR's Avatar
Default Should I be using teflon tape when connecting brake lines/components??
well im runnin some new lines on my 92 eg...i was just wondering if i can just crank the lines together with nothing on the end of the fittings....bare metal being cranked down to bare metal...or should i put some teflon tape or something on the end of the fittings instead??....i just dont want my brakes to leak and didnt know if they were made just to be cranked down and ready to go....becuase i really dont have anything i could put on to help seal/keep from making loose w/o having to go buy it.....
Old Nov 25, 2004 | 07:06 AM
Filthy Focker!'s Avatar
Default Re: Should I be using teflon tape when connecting brake lines/components?? (WyteNyteGSR)
you don't really need to. The fiitings are made to seal without the tape.
fs
Old Nov 25, 2004 | 07:19 AM
fishnfst's Avatar
They should seal fine without anything... Sometimes you can put just a dot of pipe dope on the male side of the fitting on the threads being very careful not to get any on the inside... It doesn't really act as a sealant. It is more of a lubricant to prevent galling of the metal on metal friction caused by the two threaded ends as you tighten them....
Old Nov 25, 2004 | 08:39 AM
Eyes Only's Avatar
Default Re: (fishnfst)
should be ok without tape
Old Nov 25, 2004 | 08:54 AM
thx for the help....i have one more question......if the passenger rear drum brake line was exposed to air.....do i have to bleed all 4 brakes or just the passenger front and rear??....thx in advance
Old Nov 25, 2004 | 10:34 AM
kygreenturd's Avatar
you should just go ahead and bleed all four
Old Nov 26, 2004 | 04:25 AM
Default Re: Should I be using teflon tape when connecting brake lines/components?? (kygreenturd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kygreenturd &raquo;</TD></TR><TR><TD CLASS="quote">you should just go ahead and bleed all four</TD></TR></TABLE>
no no no.. Just bleed the rear one.
fs
Old Nov 26, 2004 | 04:37 AM
2lua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WyteNyteGSR &raquo;</TD></TR><TR><TD CLASS="quote">well im runnin some new lines on my 92 eg....</TD></TR></TABLE>
be sure that you get double flare piping and fitting, cause if you don't. it will leak.
Old Nov 26, 2004 | 04:57 AM
rporter1's Avatar
Default Re: Should I be using teflon tape when connecting brake lines/components?? (2lua)
If you seal with Teflon tape, it will not leak for a little while. However, Brake fluid will eat through the tape and find a way out. If you do use teflon tape you are inviting a brake failure on which ever side of the car it was used on, either the entire front system will go out, or the entire back system. All this basically means is that not only should your brakes not need teflon tape, IT IS DANGEROUS TO DO SO!
Old Nov 26, 2004 | 05:06 AM
Default Re: Should I be using teflon tape when connecting brake lines/components?? (rporter1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rporter1 &raquo;</TD></TR><TR><TD CLASS="quote">If you seal with Teflon tape, it will not leak for a little while. However, Brake fluid will eat through the tape and find a way out. If you do use teflon tape you are inviting a brake failure on which ever side of the car it was used on, either the entire front system will go out, or the entire back system. All this basically means is that not only should your brakes not need teflon tape, IT IS DANGEROUS TO DO SO!</TD></TR></TABLE>
What the **** you talking about?
fs
Old Nov 26, 2004 | 05:16 AM
rporter1's Avatar
Default Re: Should I be using teflon tape when connecting brake lines/components?? (filthy_shovel)
I work in an auto parts store and we sell brakeline and attachments. In all of our maintenance manuals it tells about the dangers of using teflon on brakes. Teflon can eventually corrode b/c of brakefluid. Since Teflon is used to fill in holes caused by the metal not fitting flush, when it corrodes it will open up those holes again and let your brake fluid escape out the hole, leaving you with no braking power for the front or the back, which whichever end the teflon is on. This is why brake fittings are made from collapsable brass, it seals itself. If it doesn't, you need to get a new fitting.
Old Nov 26, 2004 | 07:05 AM
senpai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WyteNyteGSR &raquo;</TD></TR><TR><TD CLASS="quote">thx for the help....i have one more question......if the passenger rear drum brake line was exposed to air.....do i have to bleed all 4 brakes or just the passenger front and rear??....thx in advance</TD></TR></TABLE>
The brake line circuits are driver front - passenger rear & passenger front - driver rear; therefore, bleed the circuit that was exposed to air.
I'd do both since I'm already there
Old Nov 26, 2004 | 02:45 PM
Default Re: Should I be using teflon tape when connecting brake lines/components?? (senpai)
thx boys for the info
h-duced
Sep 14, 2011 08:23 AM
mark_is_gay
11
Oct 14, 2005 04:00 PM
tianporn
Dec 13, 2004 02:09 AM
ill phil
Aug 6, 2003 11:52 PM
