LCA compatibility? suspension swap ?'s
Old Nov 25, 2004 | 04:59 AM
chris_c's Avatar
Default LCA compatibility? suspension swap ?'s
i am pretty sure this will work but figured i'd check anyway.
i have a 93 del sol si on tein ss dampers. i plan on picking up a 96+ hatch and swapping the teins from the sol to the hatch. i know that the 96+ LCA are different [slightly narrower where the strut mounts up]. same issue that arises with the Megan LCA's in pre 96 cars.
anyway, are there any other fitment issues with the LCA if i planned on swapping the LCA from the del sol [or better yet, purchasing aftermarket LCA's for a 92-95 civic for the 96+ car?].
i believe everything else will both right up correct?
i just don't want to do the "washer" deal...
Old Nov 25, 2004 | 05:21 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: LCA compatibility? suspension swap ?'s (chris c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris c &raquo;</TD></TR><TR><TD CLASS="quote">are there any other fitment issues with the LCA if i planned on swapping the LCA from the del sol [or better yet, purchasing aftermarket LCA's for a 92-95 civic for the 96+ car?].</TD></TR></TABLE>
the 92-95 civic and del sol rear lca WILL NOT work on the 96-00 civics. sorry bro.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris c &raquo;</TD></TR><TR><TD CLASS="quote">ijust don't want to do the "washer" deal...</TD></TR></TABLE>
sorry, but i think you are stuck with it, short of buying new suspension.
Old Nov 25, 2004 | 05:22 AM
Deemeetree's Avatar
Electrician
Well, on the EG platform, it's a bit wider than that of the EK. If anything, you'll need to grind down on the bushing a little in order for the EK ones to fit.
Old Nov 25, 2004 | 06:08 AM
chris_c's Avatar
Default Re: (Dimi)
shitty...
prolly just sell the sol and start from scratch again...
mrsean008
20
Jul 25, 2015 04:16 AM
summerof2008
Mar 6, 2009 09:30 AM
TRYLSTEG808
Jan 5, 2008 12:11 AM
skip122
Feb 15, 2007 12:07 PM
deadlock32
Mar 2, 2006 07:36 PM
