Vacuum pressure on a stock ITR?
Old Nov 25, 2004 | 01:05 AM
Bbasso's Avatar
Default Vacuum pressure on a stock ITR?
I have the VAFC and would like to know what the normal Vacuum pressure is on a BONE stock ITR?
I have 539 give or take a few...
thanks.
noobie Q, I know...
Old Nov 25, 2004 | 01:17 AM
Pondus's Avatar
Default Re: Vacuum pressure on a stock ITR? (Bbasso)
well warmed up @ idle i get about -11 psi. (-570)
Stock engine with bolt ons btw.
Old Nov 25, 2004 | 07:38 AM
onyx00's Avatar
Default Re: Vacuum pressure on a stock ITR? (Pondus)
I was asking this same question earlier.
Did anyone check the Helms?
Old Nov 25, 2004 | 08:13 AM
IN VTEC's Avatar
That's plenty. A stock-cammed GS-R will idle with around -550mmHg of vacuum at 750rpm.
Old Nov 25, 2004 | 09:45 AM
totsie7944's Avatar
I just ran outside and started my car for this
Ok I know you said bone stock, and mine if obviously NOT stock but I figured I could at least post. It might be of some use to you.
The VAFC read IDLE: 890
Pressure: 488
But I also think my idle is set lower than a stock ITR? Isn't it supposed to be around 950?
Old Nov 25, 2004 | 09:57 AM
Pondus's Avatar
Default Re: Vacuum pressure on a stock ITR? (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">I just ran outside and started my car for this
Pressure: 488
But I also think my idle is set lower than a stock ITR? Isn't it supposed to be around 950?</TD></TR></TABLE>
Mine idles @ 800 after it is warmed up.
Old Nov 25, 2004 | 01:30 PM
totsie7944's Avatar
is your car stock? I dunno my idle was varying but it was anywhere from 850-900. I just took what it was most of the time.
For those that have VAFCs, when u mash the gas what does your pressure drop into? Does anyone drop into the 100-200 range? I don;t know what mine drops to, but I am going to take this chance to find out what other people are hitting.
Old Nov 25, 2004 | 01:44 PM
Pondus's Avatar
I have I/H/E on a stock engine.
WOT i get -0.4 psi or almost no vacuum, it's like -20 mmHg
Old Nov 25, 2004 | 02:50 PM
totsie7944's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pondus &raquo;</TD></TR><TR><TD CLASS="quote">I have I/H/E on a stock engine.
WOT i get -0.4 psi or almost no vacuum, it's like -20 mmHg</TD></TR></TABLE>
hmmm is that normal for his car?
Old Nov 25, 2004 | 03:38 PM
Pondus's Avatar
well it runs strong, that's for sure.
Old Nov 25, 2004 | 03:44 PM
Bbasso's Avatar
Thank you guys for responding so quick.!
I guess my number is not hat far off... But would like a stock reading to be safe.
Old Nov 27, 2004 | 04:42 PM
totsie7944's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Thank you guys for responding so quick.!
I guess my number is not hat far off... But would like a stock reading to be safe.</TD></TR></TABLE>
If it makes you feel any better, my friend has a vafc in his itr with only intake, and he says his idling number is basically the same as yours. give or take 15
Old Nov 27, 2004 | 06:20 PM
Bbasso's Avatar
Thank you .
wlee112
Jul 17, 2007 07:14 PM
uncle
Jun 18, 2004 07:48 PM
1.8Tities
Mar 6, 2003 11:18 AM
civbeater90
Feb 28, 2003 04:45 PM
93SSPHatch
Jul 18, 2002 03:18 PM
