Oversized vavles
Old Nov 24, 2004 | 11:58 PM
grenthang's Avatar
Default Oversized vavles
Would runing flat oversized ferra vavles be worth putting on my b16 build and if so with they work good with ctr pistons or would i be better off getting some type r ones
Old Nov 25, 2004 | 08:49 AM
asubennett's Avatar
Default Re: Oversized vavles (grenthang)
Stick with stock type r valves. They will flow more than enough for an N/A B16.
Old Nov 25, 2004 | 09:08 AM
grenthang's Avatar
Default Re: Oversized vavles (asubennett)
so they will work with the ctr pistons
Old Nov 25, 2004 | 10:23 AM
asubennett's Avatar
Yes, stock size valves will work perfect with CTR pistons. CTR pistons are often used with the larger 87.2mm stroke of a B18c and have clearence with high lift cams like a Toda spec C's 12.5mm of lift. You will be just fine.
aris04
Jun 4, 2004 10:38 PM
advanracing62
May 23, 2003 06:48 AM
-16V-
Oct 5, 2002 10:48 AM
Sohc Driver
11
Mar 24, 2002 05:52 AM
