done with obd1 conversion, getting code 43 on the highway
Old Nov 24, 2004 | 09:46 PM
iNetForce's Avatar
Default done with obd1 conversion, getting code 43 on the highway
i finished my obd1 conversion days ago, now im getting code 43 on the highway which is fuel supply, anybody has an idea?
Old Nov 24, 2004 | 09:51 PM
krazie1's Avatar
BANNED
Default Re: done with obd1 conversion, getting code 43 on the highway (iNetForce)
which ecu and what injectors and do u have a resistor box still??
juts like ot know what set up u have and the details regarding the fuel delivery thats all
Old Nov 24, 2004 | 10:06 PM
iNetForce's Avatar
Default Re: done with obd1 conversion, getting code 43 on the highway (krazie1)
obd0 injectors, and resistor box is there.
Old Nov 24, 2004 | 10:29 PM
eda6's Avatar
Check the o2 sensor.
Old Nov 25, 2004 | 03:11 AM
urname7698's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iNetForce &raquo;</TD></TR><TR><TD CLASS="quote">obd0 injectors, and resistor box is there.</TD></TR></TABLE>
I thought to do an OBD1 conversion you had to swap the injectors?
Old Nov 25, 2004 | 09:02 AM
iNetForce's Avatar
Default Re: done with obd1 conversion, getting code 43 on the highway (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">Check the o2 sensor. </TD></TR></TABLE>
yeah, i was thiking about it, could it be that is going bad or is bad already? would a bad o2 sensor cause the idle to jump?
Old Nov 25, 2004 | 09:52 AM
eda6's Avatar
Either the o2 sensor is bad or there's a wiring issue with the o2 sensor. It was really cold here the other day and i had a jumpy idle until the car warmed up. Maybe if the heater is on its way out it will cause jumpy idle.
Try a new o2 sensor
Old Nov 25, 2004 | 11:09 AM
mannyman's Avatar
El Veterano de Sur Califas
some people say its the o2 sensor. my cel 43 turned out to be my b&m fpr. I adjusted the screw almost all out on my fpr, since i wanted to get stock fuel pressure. But when as soon as i started my car, bam CEL. so i adjusted the screw in, and it would come on occasionally. I have since turned the screw down even more, and no CEL so far. If you have a stock fpr, try and see if you can another one to swap in, and see if fix's your prob. Hope this helps
manny
Old Nov 25, 2004 | 11:22 AM
iNetForce's Avatar
Default Re: done with obd1 conversion, getting code 43 on the highway (mannyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mannyman &raquo;</TD></TR><TR><TD CLASS="quote">some people say its the o2 sensor. my cel 43 turned out to be my b&m fpr. I adjusted the screw almost all out on my fpr, since i wanted to get stock fuel pressure. But when as soon as i started my car, bam CEL. so i adjusted the screw in, and it would come on occasionally. I have since turned the screw down even more, and no CEL so far. If you have a stock fpr, try and see if you can another one to swap in, and see if fix's your prob. Hope this helps
manny</TD></TR></TABLE>
I dont have an adjustable fpr
dem0nk1d
Aug 8, 2007 02:17 PM
HondaFerris
19
Jul 10, 2007 12:17 PM
1point5CRX
Aug 23, 2005 12:43 PM
rice is nice
Aug 22, 2005 09:08 AM
davidcrx89
11
Mar 14, 2005 07:38 AM
