Ball Bearing Turbo Oil Requirements
I was wondering if anybody had any info on restrictor size for a ball bearing turbo? Even for a thrust bearing turbo too. I think I read somewhere .060" for non bb and .035" for bb. I have a -4an to .035" restrictor from ATP and wanted to make sure it would work ok. The hole seems very very tiny
Don't want to starve the turbo
Thanks.
Nate
Thanks.Nate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic »</TD></TR><TR><TD CLASS="quote">I was wondering if anybody had any info on restrictor size for a ball bearing turbo? Even for a thrust bearing turbo too. I think I read somewhere .060" for non bb and .035" for bb. I have a -4an to .035" restrictor from ATP and wanted to make sure it would work ok. The hole seems very very tiny
Thanks.
Nate</TD></TR></TABLE>
that hole is fine, you won't starve the turbo, because it is at a constant pressure which is more important for BB applications. remember, the ball-bearings mean that it is floating on a thinner cushion of oil in its bearing system so it is not needed.
You're fine, don't overthink.
Thanks.Nate</TD></TR></TABLE>
