D16A1 (DOHC) in 90 Civic (EF)
Old Nov 24, 2004 | 07:59 PM
teg92's Avatar
Default D16A1 (DOHC) in 90 Civic (EF)
Has anyone got any information on this swap? I know that it has previously been done, but I am looking for more information before I start fabricating custom mounts.
The DOHC D16A1 is equipped with the 3 mount setup, however the SOHC D16 in a 88-91 civic is equipped with 4 mounts. I need to retain the DOHC D16A1 (L3?) tranny, therefore there is no option of running a SOHC tranny. I am wondering if there is a way to use the OE DOHC rear mount as well as somehow either use a SOHC mount bolted to the DOHC head, or if a custom drivers side mount is also required.
Any insight will be much appreciated
Old Nov 25, 2004 | 05:33 AM
teg92's Avatar
Default Re: D16A1 (teg92)
BUMP
Old Nov 25, 2004 | 06:26 AM
Sikocivic's Avatar
This swap can be done but WHY
There was someone that had a motor mount kit for this swap for about $250, do a search. I would think there alot of other swaps you can do for the same amout of money and ALOT less work. If you really want to use that motor then find a 86-87 CRX-Civic Si and it will bolt right in to one of those cars. If you to keep the 88-91 Civic then go with a DOHC ZC or you can build the SOHC motor for the same amout of money you would have in the D16a1 swap.
Old Nov 25, 2004 | 08:50 AM
The DX Rex's Avatar
i had a D16A1 in my 89 hatch dx. i used my sohc tranny so i have no clue how u;d set up another tranny. but to be honest, ur better off putting an 88-91 si d16a6 motor in it. it is the same thing. only difference with the DOHC is it will be louder engine.
also these motors tend to spin bearings so be very careful cuz mines went on me.
Old Nov 25, 2004 | 09:06 AM
davens's Avatar
Engine swap for 10hp? No thank you.
Old Nov 25, 2004 | 01:33 PM
teg92's Avatar
Default Re: (davens)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">Engine swap for 10hp? No thank you.</TD></TR></TABLE>
See, you're assuming I am talking about a stock engine. However in this case, I have a fully built D16A1 with an extensively modified D16A1 transmission to go along with it. If it was stock, obviously this swap would make no sense!
Old Nov 26, 2004 | 01:11 PM
teg92's Avatar
Default Re: (teg92)
bump for today
Old Nov 26, 2004 | 01:18 PM
MENACE's Avatar
Default Re: (teg92)
It Can fit i had a friend that put one in his rex. He had to make a new Driver side motor mount so it would fit.
However in his case is was not worth it. The mount held up but the motor blew about 10days later.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nyhustla2k &raquo;</TD></TR><TR><TD CLASS="quote">
also these motors tend to spin bearings so be very careful cuz mines went on me.</TD></TR></TABLE>
Thats how it Died.
Im sure some people will chime in and tell you its a waste of time.
And maybe for a Completly stock motor it is. But if its built then i say go for it. Good luck to you, and good luck on the fabing of the drivers motor mount.
Old Nov 26, 2004 | 01:26 PM
teg92's Avatar
Default Re: (MENACE)
Thanks. Well yes, the motor is completely built for road racing, very high end parts inside.
Interesting you say he had to make a custom drivers side mount. By a visual inspection, we believe the factory SOHC drivers side mount will bolt onto the DOHC. Do you have any insight on this?
Old Nov 26, 2004 | 02:33 PM
MENACE's Avatar
Default Re: (teg92)
Truthfully i dont i Was supposed to help him Fab it, but i never made it out that day. I personally was thinking the same thing. Just bolt up the SOHC mount.
He clamed that it wouldn't fit. But i wasn't there to make sure he wasn't just trying to put the mount on and not the whole mount assembely. I didn't question it enuff Cuz i didn't want to make him think he did all that work for nothing, if for some reson my thoery worked.
The way i see it, you have the SOHC mount, Its not like its that hard to unbolt one from the block. Hell you have to do that when you change a timming belt anyways. I say give it a try. Really you have nothing to loose.
Sorry for not being much more help. But this was done like 8 months ago, and it only lasted 10 days lol. So it wasn't really etched into my mind .
Old Nov 26, 2004 | 02:40 PM
Garrett's Avatar
The big problem with this swap isn't the driver side mount
it'S the thermostat housing that doesn't clear the tranny
Old Nov 26, 2004 | 02:41 PM
Garrett's Avatar
Default Re: (Garrett)
Old Nov 26, 2004 | 05:31 PM
jhota's Avatar
Default Re: (teg92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg92 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks. Well yes, the motor is completely built for road racing, very high end parts inside.
Interesting you say he had to make a custom drivers side mount. By a visual inspection, we believe the factory SOHC drivers side mount will bolt onto the DOHC. Do you have any insight on this? </TD></TR></TABLE>
the SOHC mount would interfere with the timing belt on the DOHC engine.
i've tried it.
easiest route would probably be get a DOHC ZC block mount (if you can find one).
Old Nov 26, 2004 | 06:10 PM
StupidSlowRSX's Avatar
Default Re: (jhota)
I had a D16A1 with the following Mods in an 89 CRX DX.
Port+polished head
3 Angle valve
Bored and Port matched Intake Mani
65mm bored TB
4-2-1 Header
2.25 Exhaust
Intake
B&M FPR and Gauge
Wasnt even in the 14's.. The Valve cover is for sale though
Old Nov 26, 2004 | 07:48 PM
Ckjeepin's Avatar
Default Re: (StupidSlowCRX)
u suck at driving...
By dohc zc with just intake and exhaust cutout ran 15.3..
Old Nov 27, 2004 | 03:45 PM
Default Re: (Ckjeepin)
No... To tell you the truth the motor just plain out sucks for all motor applications.. There great boosted motors, the internals love it
B series &gt; D series more expensive yes... but definetaly worth the money!
wing.jai
10
Feb 17, 2009 08:23 PM
Si2See
Apr 12, 2008 12:12 PM
92TypeR
Northwest (Sales)
Apr 15, 2007 12:18 PM
illestrolla247
13
May 24, 2005 10:19 AM
tangb2023
Nov 5, 2003 01:51 PM
