will a thinner head gasket raise hp? cometic or stock y8
as u read . im putting my y8 head back on my y8 block but if i put a thin head gasket will i get more hp from the higher comprecion. thank
you will gain a SMALL amount of hp because for every .010 you deduct from your head gasket (which equals approx 1 layer) your compression will increase by only .2
Example: If you had a stock engine running 10.0:1 using a stock 3 layer headgasket (.030 thick) and you used a 2 layer headgasket (.020) in there, your compression would increase to 10.2:1
I doubt you'd even be able to feel the slight difference in power a change like that would make. Higher octane fuel wouldn't be required for a small change like this.
Texas4door
Dec 5, 2011 08:36 AM
haroldthefly91crx
Aug 14, 2006 08:26 PM
Wes90civic
Jan 19, 2004 11:13 PM
add, cometic, compression, difference, feel, gain, gasket, head, headgasket, hp, increase, thin, thinner, wil, y8
