ecu need help
what`s up guys.just wondering what ecu to run,I`m doing an A6/Z6 mini-me,what ecu should i run pm6 or p28 and which dizzy i know the a6 dizzy doesn`t mount up right what about the z6.Oh yeah btw i have a chipped pm6 i seen a thread,this guy fabrik8 or something like that said that he could take a chipped pm6 and i guess add another chip or something so it could enegage v-tec. Is this possable anyone heard of this and if it does work would it be better than using the vafc hack. Thanks for any help
you can use either ecu but you need to use the dist. that matches that ecu. with the p28 you need the obd1 dist. and conversion harness and the ecu will activate vtec. using the pm6 ecu you'll need to use an rpm switch to activate the vtec. i sent a pm6 to zdyne and only had to run one wire to the ecu fron the solenoid to activate vtec. i think hondata also makes an ecu that will run it? as far as modifying the a6 dist. you have to to mount it to the z6 head i've got a thread that shows how i did it and how another guy did it. the way he did it seems to be the better. let me find it and i'll post it.
cityofcaterpillars
Engine Management and Tuning
Apr 13, 2016 07:06 PM
littlemracura
Aug 17, 2004 02:13 PM
