Some one help me please??
I bought some platinum plugs for my 91 si today. When i went to remove my old plugs, i noticed oil on the ends of my spark plug wires! What is wrong? I did overfill my oil once, but it is slowly leaking out, so i didnt think much of it. Anything i can do to correct this? Any long term harms?
check to see if it occours again then ensure plugs are torqued to proper spec also you may wanna look into replacing your valve cover seals
[Modified by dohcvtec16, 7:19 PM 12/29/2001]
You need spark tube gaskets, valve cover grommets and probably a valve cover gasket. You might be able to clean your plug wires- but should probably replace them if they are swollen. Get some Honda wires or NGK wires. I would stay with NGK or Denso plugs too- just FYI. Platinum is really a waste of money unless you have a real need for them.
rebeltshead
Dec 29, 2008 03:03 PM
Takymoto
Feb 17, 2007 05:51 PM
