how to install wheel spacers
Old Nov 24, 2004 | 07:26 PM
glarock's Avatar
Default how to install wheel spacers
Stupid question, but I'd rather not have a wheel fall off in an autocross...
So I read that in order to run 225 width tires up front, I'll need some 5mm spacers. Picked up some of these:
http://www.optionimports.com/1065640.html
Now I'm not entirely sure what I'm supposed to do with them. They're narrow enough that I'd be tempted to just put them on the hub, then the wheels, both on the stock bolts. How much thread do I need on the bolts to hold the wheel on securely?
If that won't work, I presume that's when I'm supposed to use the bolts that came with the spacers. Where exactly do those go? No instructions came with the spacers.
Any help appreciated.
Happy Thanksgiving.
Gary
Old Nov 24, 2004 | 10:05 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: how to install wheel spacers (glarock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by glarock &raquo;</TD></TR><TR><TD CLASS="quote">How much thread do I need on the bolts to hold the wheel on securely?</TD></TR></TABLE>
The standard rule of thumb is that you need six full turns.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by glarock &raquo;</TD></TR><TR><TD CLASS="quote">If that won't work, I presume that's when I'm supposed to use the bolts that came with the spacers. Where exactly do those go?</TD></TR></TABLE>
They should be replacements for the stock studs (the big bolts that the lug nuts fasten onto the ends of).
Old Nov 25, 2004 | 07:49 AM
glarock's Avatar
Default Re: how to install wheel spacers (nsxtasy)
Excellent, thanks for your help.
Gary
Flux
Dec 27, 2006 01:33 PM
LiL JoN
Aug 30, 2006 09:49 AM
dnasol
Jul 1, 2005 04:44 PM
JDM_Type-R
Jul 10, 2004 03:50 PM
zRd#1
May 14, 2003 11:46 PM
