Lowering springs
Old Nov 24, 2004 | 06:55 PM
H22A4Me's Avatar
Default Lowering springs
do i need a caster camber kit if i get springs or coilovers, if i dont will it wear out the different areas of the tires.
Old Nov 24, 2004 | 07:00 PM
CFLude97's Avatar
Default Re: Lowering springs (PreludeH22A4Me)
I heard if you drop it more than an Inch you need a camber kit...im sure some one here can say if this is true or not.
Old Nov 24, 2004 | 09:51 PM
john d
Guest
Posts: n/a
Default Re: Lowering springs (CFLude97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CFLude97 &raquo;</TD></TR><TR><TD CLASS="quote">I heard if you drop it more than an Inch you need a camber kit...im sure some one here can say if this is true or not.</TD></TR></TABLE>
more than likely, if you lower the car from factor height
i heard cutting your springs work best- handling/ride quality
Old Nov 24, 2004 | 09:57 PM
aboh6leenz's Avatar
Default Re: Lowering springs (john d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">i heard cutting your springs work best- handling/ride quality</TD></TR></TABLE>
i heard cutting your springs are bad. Not as strong as aftermarket springs and they werent meant to be cut. But, i'm not sure and i'm probably wrong.
oh and i have some camber wear but my car isnt even lowered????
Old Nov 25, 2004 | 12:45 AM
bad-monkey's Avatar
don't cut stock springs.
don't lower without new shocks.
and you don't NEED a camber kit. camber doesnt screw up your tires nearly as much as TOE does.
get an alignment after you lower.
Old Nov 25, 2004 | 03:51 AM
IAluder95's Avatar
i have no camber kit and i didnt realign my car after i lowered it 2+ inches. no problem yet. no wear of tire or bad ride. my car doesnt drive to one side either. that on GC Coilovers and Koni Yellows.
and once again: DONT CUT YOUR SPRINGS!!!
Old Nov 25, 2004 | 07:12 AM
john d
Guest
Posts: n/a
Default Re: Lowering springs (aboh6leenz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aboh6leenz &raquo;</TD></TR><TR><TD CLASS="quote">
oh and i have some camber wear but my car isnt even lowered????</TD></TR></TABLE>
ugh... i was jk you n00b , are you kidding me?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TopNotch_Lude &raquo;</TD></TR><TR><TD CLASS="quote">i have no camber kit and i didnt realign my car after i lowered it 2+ inches. no problem yet. no wear of tire or bad ride. my car doesnt drive to one side either. that on GC Coilovers and Koni Yellows.
and once again: DONT CUT YOUR SPRINGS!!!</TD></TR></TABLE>
good job of repeating stuff
Old Nov 25, 2004 | 07:28 AM
ludegetsmwet's Avatar
Default Re: (TopNotch_Lude)
well topnotch there may be problems that are occuring that you don't know about and when they do become apparent it will be some $ to fix it.
Old Nov 25, 2004 | 10:13 AM
IAluder95's Avatar
what could possibly be getting messed up that a camber kit could fix?
Old Nov 25, 2004 | 12:42 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TopNotch_Lude &raquo;</TD></TR><TR><TD CLASS="quote">what could possibly be getting messed up that a camber kit could fix?</TD></TR></TABLE>
it's not the camber alone that's the issue, it's the alignment in general. camber, caster, toe etc.
alignments are a good thing.
Old Nov 25, 2004 | 01:08 PM
aboh6leenz's Avatar
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">ugh... i was jk you n00b , are you kidding me? </TD></TR></TABLE>
Oh okay thanks. I was just stating that i didnt think it was a good idea i didnt know you were joking. Thanks for being nice !
Hah atleast i only have -2% you got -3% haha j/p.
Old Nov 25, 2004 | 04:01 PM
john d
Guest
Posts: n/a
Default Re: (aboh6leenz)
Hah atleast i only have -2% you got -3% haha j/p. and im gay</TD></TR></TABLE>
ughh.. are you proud of that? does it help you sleep?
Old Nov 25, 2004 | 04:10 PM
IAluder95's Avatar
i never said an alignment was a bad thing. of course its a good thing. esp. when you have to hold the wheel all the way to the right just to go straight.
what i was implying was. i drop my car and did neither and so far nothing has gone bad.
Old Nov 25, 2004 | 06:50 PM
Boost Addict's Avatar
My car has been dropped for over 3 years with no camber kit. I could prob use one, but I'm just too lazy to go out and do it.
Old Nov 25, 2004 | 09:21 PM
aboh6leenz's Avatar
Default Re: (Boost Addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">ughh.. are you proud of that? does it help you sleep? </TD></TR></TABLE>
Whats wrong with you. I was just playing. I even stated it. You dont got to be mean about it. It's over now get over it.
chickenwing
Oct 26, 2008 06:45 AM
mikeunreal
Suspension & Brakes
26
Nov 21, 2005 01:47 PM
barely4dr
Suspension & Brakes
Aug 8, 2005 01:54 PM
spooniq
Honda S2000
Sep 7, 2004 01:04 PM
otb2000itr
Honda S2000
21
Sep 5, 2004 08:41 AM
