Automatic Transmission that will hold Turbo?
Old Nov 24, 2004 | 06:51 PM
driftturbo's Avatar
Default Automatic Transmission that will hold Turbo?
I'm looking for someone that can build an automatic transmission that will hold power about 400-500fwhp on a B18. I tried doing a search but nothing came up. Anyone have any ideas?
Old Nov 24, 2004 | 07:57 PM
Chip's Avatar
Default Re: Automatic Transmission that will hold Turbo? (driftturbo)
You must swap to a standard at those levels. IIRC there was some mention of a GM automatic tranny, but that's a VERY expensive setup and totally geared towards drag racers, not a street car. Are you afraid to drive a stick or what?
Old Nov 24, 2004 | 08:25 PM
atcrx's Avatar
Default Re: Automatic Transmission that will hold Turbo? (Chip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chip &raquo;</TD></TR><TR><TD CLASS="quote">You must swap to a standard at those levels. IIRC there was some mention of a GM automatic tranny, but that's a VERY expensive setup and totally geared towards drag racers, not a street car. Are you afraid to drive a stick or what?</TD></TR></TABLE>
Why not a honda auto? Has anyone besides level ten tried to build one. I have done some research on the idea. The honda AT in a b-series motor is a lot like a straight shift. It just uses clutch packs instead of sliders and shift forks. What tears up on a AT trans? Does it slip? Is the converter the issue?
Old Nov 24, 2004 | 09:33 PM
BoostR41's Avatar
Default Re: Automatic Transmission that will hold Turbo? (atcrx)
call level 10 in jersey and see what they say
Old Nov 25, 2004 | 03:04 AM
Tony the Tiger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driftturbo &raquo;</TD></TR><TR><TD CLASS="quote">I'm looking for someone that can build an automatic transmission that will hold power about 400-500fwhp on a B18. I tried doing a search but nothing came up. Anyone have any ideas?</TD></TR></TABLE>
http://www.importperformancetrans.com/index.shtml
This shop built the automatic transmission on my Camry V6 to hold 357+ WHP. Now it is holding much more power than that with the new turbo and built motor.
They specialize in all imports, from Hondas, Nissans, Toyotas, even DSM's. It will be expensive though, and certainly won't be an easy upgrade.
I had a Level10 before this and that crap blew up in one pull.
Old Nov 25, 2004 | 11:41 AM
driftturbo's Avatar
Default Re: Automatic Transmission that will hold Turbo? (Tony the Tiger)
Tony,
Thanks for the information. How long have you had your transmission? how's everything hold up. mileage? I'll give them a call on monday.
RoboKillaHoe
Honda Civic (2001 - 2005)
24
Apr 14, 2011 06:16 PM
418whpturboD
Oct 30, 2008 08:16 PM
MrPl2e5t0n
Nov 9, 2007 09:33 PM
slowh23
May 5, 2006 09:41 PM
boat'scivic
Apr 19, 2004 07:14 AM
