differences in front LCAs
Old Nov 24, 2004 | 06:05 PM
ek_will's Avatar
Default differences in front LCAs
i noticed my front LCAs are different from each other one has sway bar holes and one does not. are all LCAs equal in length? would they cause odd camber?
just thought i might check it out before i upgrade my suspension. tia
Old Nov 24, 2004 | 06:26 PM
Built to Spill's Avatar
el diablo
You should have holes in both lca's.
Old Nov 25, 2004 | 06:34 AM
ek_will's Avatar
Default Re: (Built to Spill)
i should probably take a look at it again then, otherwise all front lcas that would be interchangable with a 96-00 civic are the same length n spec right?
Old Nov 26, 2004 | 05:37 PM
ek_will's Avatar
Default Re: (dash_0n)
bump
Old Nov 27, 2004 | 09:08 PM
pancake56's Avatar
you've been part swapped
Old Dec 1, 2004 | 04:31 AM
ek_will's Avatar
Default Re: (pancake56)
looks like it, well i got myself another LCA from a buddy and will it will be on soon. still no definite answer on the specs of lca being different or not.
Old Dec 1, 2004 | 04:44 AM
kay_animation's Avatar
Default Re: differences in front LCAs (dash_0n)
to my knowledge, there is no difference in length between the 96-00 front lca, but of course only a left lca will fit a left lca, and a right will fit a right, but size wise they are both the same, just different depending on what side they go on. 99-00 si lca's are a different story though. They are the same width but will not bolt up to 96-98 ek lower shock forks or 99-00 non si lca as well I think but i'm not sure about the 99-00 part, but 96-98 for sure lower shock forks will not bolt up to 99-00 lca's.
Assuming you were asking about an ek
I can tell you more if you want.
Old Dec 1, 2004 | 05:00 AM
ek_will's Avatar
Default Re: differences in front LCAs (kay_animation)
yeah its for a 98 EK, so what is this mysterious LCA that i have on? what LCAs are interchangable for my car? btw its a 98 EK w/ itr 5 lug conversion but im assuming teg LCAs wouldnt fit am i correct?
Dikon0901
Suspension & Brakes
Aug 25, 2013 10:50 PM
Frozen E
Aug 15, 2004 06:22 PM
Ehron
Feb 16, 2004 11:08 AM
patman18
Dec 14, 2003 06:54 PM
EricUSC
Jan 25, 2003 12:23 PM
