what is the lowest offset you will go on your itr???
Old Nov 24, 2004 | 06:03 PM
jeremy.'s Avatar
Default what is the lowest offset you will go on your itr???
because i am about to pickup a set of rims with a 32+ offset....i want to know if that is too much and will not stick out too far? thanks for any help
Old Nov 24, 2004 | 06:04 PM
BlueR's Avatar
Default Re: what is the lowest offset you will go on your itr??? (ekay_jeremy)
we just went through this...
https://honda-tech.com/zerothread?id=1059341
Old Nov 24, 2004 | 06:54 PM
jeremy.'s Avatar
Default Re: what is the lowest offset you will go on your itr??? (BlueR)
that thread didn't finish though...the guy said it fit but will post a pic
Old Nov 24, 2004 | 09:30 PM
jdmspoonitr's Avatar
It will be fine. It shouldn't stick out much if any. It will be flush with the fender. Just make sure you aren't too low and make sure you are running decently stiff rates.
Old Nov 24, 2004 | 10:24 PM
Dr. EKology's Avatar
Say good-bye to your tires and inner fenders unless you are ready to work them a bit.
Old Nov 25, 2004 | 01:26 AM
Pondus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">because i am about to pickup a set of rims with a 32+ offset....i want to know if that is too much and will not stick out too far? thanks for any help</TD></TR></TABLE>
How wide are these wheels? I have a set of 15x7" +38 wheels and they fit without any issues, but +32 is pushing it. It also depends on your tiresize though if you will have to roll fenderlips or not.
Old Nov 25, 2004 | 05:18 AM
George Knighton's Avatar
H-T Order of Merit
Default Re: what is the lowest offset you will go on your itr??? (jdmspoonitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote">It will be fine. It shouldn't stick out much if any.</TD></TR></TABLE>
Are you sure about that? My +38 15x7 wheels are <u>right</u> on the edge in the rear if I have decent-tread R comps on the car.
Old Nov 25, 2004 | 07:48 AM
jeremy.'s Avatar
Default Re: what is the lowest offset you will go on your itr??? (George Knighton)
anyone else?
Old Nov 25, 2004 | 09:14 AM
Hahahah George I have the same wheels. Kosei K1 15" +38. My car has a bit of negative camber in the rear so the top of the tire does not stick past the quarter panel, it however does hit the inner lip of the fender liner if I go up driveways and what not.
But aesthetically the wheels do not stick out past the quarter panel. Looking from the back. If I had my rear camber kit in that might be different.
Old Nov 25, 2004 | 06:04 PM
99 TYPE R's Avatar
u will be fine my advans are 16 x 7, 31mm offset and they r fine i had to raise my car up a half inch, and tighten my suspension up.
Old Nov 25, 2004 | 06:23 PM
jeremy.'s Avatar
Default Re: (99 TYPE R)
i saw your last post...do you have any pics?
Old Nov 25, 2004 | 09:16 PM
99 TYPE R's Avatar
nah not yet sorry man
Old Dec 21, 2004 | 02:59 PM
jeremy.'s Avatar
sorry but a quick update i have 32+ offset wheels on my type r and no trouble at all....doesn't stick out too far to my likings or rub what so ever.
Old Dec 21, 2004 | 03:06 PM
AnToNy's Avatar
Default Re: (ekay_jeremy)
Sweet *** R, love the offset
Old Dec 21, 2004 | 03:16 PM
nightrider's Avatar
Default Re: (jaedaSC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaedaSC &raquo;</TD></TR><TR><TD CLASS="quote">
Sweet *** R, love the offset</TD></TR></TABLE>
Old Dec 21, 2004 | 03:48 PM
mugenracer's Avatar
I have a set of Modex rims, theyre 16x7 with a +35 offset and they tuck in fine, with no rubbing and my suspension is pretty low at the rear. I'd say you should be ok with 32, try them and see!
Old Dec 21, 2004 | 03:51 PM
jeremy.'s Avatar
Default Re: (mugenracer)
i did try them....
Old Dec 21, 2004 | 03:55 PM
mugenracer's Avatar
sorry missed that post :?
Old Dec 21, 2004 | 03:57 PM
jeremy.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">sorry but a quick update i have 32+ offset wheels on my type r and no trouble at all....doesn't stick out too far to my likings or rub what so ever.
Old Dec 21, 2004 | 07:20 PM
-Infinity-'s Avatar
FREEMAN!!!!!! Sorry I had to.
Old Dec 21, 2004 | 07:22 PM
RTW DC2R's Avatar
Old Dec 21, 2004 | 08:55 PM
Black R's Avatar
25 Year Member
....try 15x10, +0 offset.
Oh yeah: roll the fenders with said combo.....
Old Dec 21, 2004 | 09:07 PM
97 TYPE-R 312's Avatar
I rubbed at Summit Point with my SSR TYPE-C's +38 15x7's 205-50VR15 AZENIS, in the rear, stock suspension, 75K miles.
-Victor
Old Dec 21, 2004 | 11:46 PM
GIANT's Avatar
Anymore pics of this car?
Old Dec 23, 2004 | 02:21 PM
jeremy.'s Avatar
Default Re: (GIANT)
i'll get some better ones soon
