vaccum leak at master cyl.
Old Nov 24, 2004 | 03:55 PM
glass1's Avatar
Modified by glass1 at 7:48 AM 11/26/2004
Old Nov 24, 2004 | 04:22 PM
Tmack's Avatar
Default Re: vaccum leak at master cyl. (glass1)
there is no vaccum in your master cylinder, there is however vaccum in your brake booster. Check the valve that the tube from the intake goes into for clogging. it might just be time for a new booster and no they cant be rebuilt.
Old Nov 24, 2004 | 05:00 PM
glass1's Avatar
Default Re: vaccum leak at master cyl. (Tmack)
Modified by glass1 at 7:49 AM 11/26/2004
Old Nov 24, 2004 | 08:15 PM
WhiteGSR95's Avatar
its probably time for a brake booster. to check for a bad booster. with the car off pump the brakes till the pedal gets hard. keep the pedal pressed and turn on the car. if its good u should be able to not hear any leaks and other abnormal sounds, and the pedal should go down. i doubt that ure master cylinder is leaking. check it for leaks. and about the car holding back im not sure
thecruzs2007@yahoo.com
Mar 20, 2010 03:52 PM
civicexowner
Jun 18, 2009 03:07 PM
mattbatson
Oct 23, 2008 07:30 PM
sinister2c
Jul 1, 2004 10:23 PM
KekeK-18
10
Apr 28, 2002 09:38 PM
