drive axle replacement ?
Old Nov 24, 2004 | 03:40 PM
accordmurf's Avatar
Default drive axle replacement ?
about how long does it take to do a drivers side driveshaft replacement with 2 guys and all tools on a 94 accord ex (manual), i'm looking for estimates here not exact times
Old Nov 24, 2004 | 04:50 PM
hawkmgc's Avatar
Default Re: drive axle replacement ? (accordmurf)
Took me only 1/2 hrs time with air to do mine on a 91 EX.
First time ever did one took me about 1.15 hrs.
Old Nov 24, 2004 | 06:09 PM
dan1220's Avatar
Default Re: drive axle replacement ? (hawkmgc)
its easy, the hardest part for me was gettin the axle nut off, and gettin the ball joint seperated
Old Nov 24, 2004 | 08:56 PM
brads94accord's Avatar
i took me about 45 minutes to do my passenger side, but 15 of that was waiting for my dad to come back from the auto parts store picking up some oil for me since i couldn't driveto the auto parts store in my car and i was covered in grease from the busted cv boot.
my drivers side took me about 45 minutes too, but about 30 of that was spent trying to seperate the old axle from the halfshaft. i finally got it with the help of my roomate pulling on the axle while i hit the crap out of the old axle with a hammer until it poppped loose.
its very easy, i recommend investing in a two jaw gear puller. it makes separating that lower ball joint very very easy.
Old Nov 25, 2004 | 08:38 AM
4thgen92accord's Avatar
on my EF it took about an hour....once you get the axel bolt off its pretty much cake,but on my axel bolt..ohh...had to put a cheater bar to it...air wouldnt get it off. The cheater bar was, hmm, about 12 ft. long and 3 in. diameter. lol
Old Nov 25, 2004 | 10:00 AM
jagged4698's Avatar
Default Re: drive axle replacement ? (4thgen92accord)
Sorry to jack the thread but i'm trying to replace my rotors and part of that process involves removing the drive axle nut.....How the hell do you get that off of there.....what size socket is it....I have tried to use a vice grip and a steel pipe but that isn't working and i'm afraid if i go any further with it then i will strip the nut....HELP....
Old Nov 25, 2004 | 12:27 PM
its a 36mm socket, you will need a pretty big pipe extension on a breaker bar. next time do a search. the search button is your friend. this topic has been covered numerous times.
Old Nov 25, 2004 | 01:15 PM
jagged4698's Avatar
Default Re: (brads94accord)
I tried to do a search but it said it was down...so i could not complete the search.... Thanks though.
Old Nov 25, 2004 | 04:19 PM
TOAB's Avatar
depends on how you get the balljoint to come loose... 1/2-1 1/2 hours.
btw if you got a dead blow hammer its better than a balljoint splitter... it wont **** your boot
Old Nov 25, 2004 | 04:29 PM
StimpyBoy's Avatar
Default Re: (TOAB)
If it's anything like the 4th gens, it's almost easier to just undo the LCA to frame bolt, radius rod to LCA and sway bar to LCA. You can then get enough play to move the LCA out of the way to let the axle be removed.
It's a few more bolts, but I'd take that over separating the ball joint anyday. Well, maybe not now that I bought a special tool to do so
Old Nov 25, 2004 | 06:43 PM
asianpoet's Avatar
30 to an 1 if you know what your doin.. but if your takin your time..like I do.. it takes me two hours..
Old Nov 25, 2004 | 08:27 PM
this tool is you friend when it come to seperating the lower ball joint. it takes me about 2 minutes to seperate it.
Old Nov 26, 2004 | 01:43 AM
TOAB's Avatar
just do the upper... takes less than a minute
jmurphy
17
Apr 5, 2011 01:19 PM
imbest123
Nov 10, 2009 10:09 AM
dextR
Sep 16, 2005 07:49 AM
TheJunBuilt
Oct 15, 2004 08:32 AM
