does anyone here put synthetic oil in there stock civic engines?
Old Nov 24, 2004 | 02:25 PM
moreno's Avatar
Default does anyone here put synthetic oil in there stock civic engines?
just curious..
Old Nov 24, 2004 | 02:40 PM
ThatsMyEG's Avatar
Default Re: does anyone here put synthetic oil in there stock civic engines? (moreno)
i do
Old Nov 24, 2004 | 03:19 PM
teknoracing's Avatar
Default Re: does anyone here put synthetic oil in there stock civic engines? (B20ZVTECHB)
Its not really necessary if you change your oil on a regular scheduled maintenance and only have bolt ons. I would definitely use it if forced induction is involved.
Old Nov 24, 2004 | 03:27 PM
unbelievableEG's Avatar
Default Re: does anyone here put synthetic oil in there stock civic engines? (teknoracing)
i do, or well did heh
Old Nov 24, 2004 | 03:31 PM
project-boosteD's Avatar
Default Re: does anyone here put synthetic oil in there stock civic engines? (unbelievableEG)
all i gots an intake and a cat-back...and its working good with me....
Old Nov 24, 2004 | 04:02 PM
94CoupeEJ1's Avatar
I use it in every engine I own including 2 lawn mowers and a tiller. Mobil 1
Old Nov 24, 2004 | 05:14 PM
fishnfst's Avatar
I've been running Mobil 1 since I boosted my hatch... It seems to burn a little oil with the synthetic... It goes through about half a quart every 3000 miles. I normally do my oil changes every 2000 so it is normally down about a quarter of a quart... I switched back to castrol gtx and it no longer consumes oil... I don 't know why that is but try it and see if it works for you...
Old Nov 24, 2004 | 05:22 PM
TheShad0w's Avatar
Default Re: (fishnfst)
I use it in all my cars, better millage, motor runs so much better under long term stress in traffic.
Old Nov 24, 2004 | 09:58 PM
nyteryda3's Avatar
Default Re: (TheShad0w)
yup... better mileage and motor runs much cleaner.
Old Nov 24, 2004 | 10:11 PM
SOHC4life 96's Avatar
Default Re: (nyteryda3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknoracing &raquo;</TD></TR><TR><TD CLASS="quote">Its not really necessary if you change your oil on a regular scheduled maintenance and only have bolt ons. I would definitely use it if forced induction is involved. </TD></TR></TABLE>
Yeah, I don't know what you're talking about. Most people who use synthetic because it is better oil all together. Not because they have a higher performance engine. I got better gas milage and my car ran much smoother when I switched to Castrol Syntec. It doesn't burn any oil either.
I refuse to use Mobil 1 because of all the people who say their B or D series burns Mobil 1 all the time.
Old Nov 24, 2004 | 10:57 PM
murmur9's Avatar
Default Re: (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life &raquo;</TD></TR><TR><TD CLASS="quote">
I refuse to use Mobil 1 because of all the people who say their B or D series burns Mobil 1 all the time. </TD></TR></TABLE>
....Do you know what your talking about?
Old Nov 24, 2004 | 11:19 PM
hondainspired's Avatar
Default Re: (murmur9)
i think its one thing to switch to a synthetic but to go back is where i'm a lil weary... because i did the same thing with my b20a5 (3rd gen. prelude) and i fried rings...
Old Nov 25, 2004 | 03:54 AM
SSExpo's Avatar
I run Mobil 1 in all my engines, but switch to Royal Purple once I go forced induction.
Old Nov 25, 2004 | 04:10 AM
slambedcivic's Avatar
Default Re: (SSExpo)
amsoil
ive gotta stock internalled B18B.. turbo setup.. synthetic oil doesnt break down as easy as non synthetic, and with the tempatures that the engine reached because of the turbo, you need something that has a higher breakdown point.. plus amsoil gaurentees their oil
Old Nov 25, 2004 | 05:01 AM
chris_c's Avatar
Default Re: (slambedcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic &raquo;</TD></TR><TR><TD CLASS="quote">amsoil
another amsoil user here...
Old Nov 25, 2004 | 06:38 AM
94CoupeEJ1's Avatar
I use Mobil 1 and my engine doesn't burn a drop. I go 10,000 miles between changes without adding. 90K on D series.
Old Nov 25, 2004 | 07:20 AM
Dreamworx's Avatar
Default Re: (94CoupeEJ1)
I use mobil 1 european formula(0-40)... only because it is free from my job
Old Nov 25, 2004 | 07:42 AM
Honissan's Avatar
Don't waste your money on synthetic, its all hype, just like that freakin' crap they put in GM's and now FORD's to replace antifreeze, they use synthetic dexcool. Just do your oil changes with a good oil and you will get the same effects if you spent 4 more dollars a quart on synthetic. Just my .o2. I could be wrong about it being a complete waste of money, but I haven't seen it make a big difference.
Old Nov 25, 2004 | 08:25 AM
markeverett's Avatar
I work at a company where we are testing performance engines on a regular basis. We have poven multiple times that Mobil 1 is the oil to use. We used to think that you had to break the engine in with standard oil and then switch to synthetic. Multiple times we pushed too hard with the standard oil in the engine and spun main bearings, rod bearings, etc. Take the same engine, replace the bearings, put Mobil 1 in and the bearing problems would go away.
We now start every dyno test with Mobil 1 in the engine whether it's a brand new engine, freshly rebuilt, or an old dyno mule.
I also use it in my D series - noticed an engine temp drop after replacing standard oil. Haven't gone as far as putting it in the lawnmower as others have mentioned.
Mark
Modified by markeverett at 10:04 AM 11/25/2004
Old Nov 25, 2004 | 11:12 AM
Ek9Hybrid's Avatar
I use to use Mobil 1 in my car. too expensive for a factory d motor. when I swap it I'll use Mobil 1
Old Nov 25, 2004 | 11:35 AM
t0ekn3e's Avatar
I use synthetic oil for my car. Also where i work Jiffy Lube they told me that Mobil 1 makes the majority of the other companies synthetic oil also because the refineries cost too much, im not sure how true this is but im just throwing it out there.
Old Nov 25, 2004 | 11:40 AM
Quad-Damag's Avatar
Default Re: (t0ekn3e)
i have always done so, after i bought the car, and I belive thats one of the main reason i have yet to blow up the motor or head to this date,(stock for 4 months then moded for over 2 years) boosted 12 psi dayily driving and raced on alot, it's holding up very nice, for now
still slow tho
Full Syn 10w 30
Old Nov 25, 2004 | 12:00 PM
kygreenturd's Avatar
Default Re: (Quad-Damge)
i use synthetic and it runs cooler than regular oil
i just like synthetic more
Old Nov 25, 2004 | 12:01 PM
mzboy's Avatar
Default Re: (kygreenturd)
Mobil 1 Synthetic here, haven't noticed any huge differences.
Old Nov 25, 2004 | 02:59 PM
Default Re: (chris c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris c &raquo;</TD></TR><TR><TD CLASS="quote">
another amsoil user here... </TD></TR></TABLE>
