Threw CEL, need help
Hey everyone.
1991 Civic Si Hatch with a 1989 blacktop ZC. I'm throwing 17 (which I know is VSS, don't care. Speedo is unplugged), and 8, which is...?
I don't know what it is, nor how to correct it. Help
Edit: Ok, it appears to be a TDC sensor. I'm not sure where that's located.
Code 8 - Top Dead Center Sensor
It's the second sensor in the dist. It can also be located on the camshaft of DOHC engines. It determines the injection timming for each cylinder, also used to detect engine speed (rpm) to read the basic discharge duration, for different operating conditions.
If the dist. base bearing starts failing, it will heat the sensor(s) up, destroying the magnetism thus causing a code(s). It will lose 10% of it's strenght, each time it is heated up, to a 170 degrees plus.
In most cases, replacing the distributor is the only alternative. Especially if the bearing has failed.
Honda does don't stock the bearing, but other after-market compaines are said to have one.
If you have problems starting the engine, or drivability after the install check your cam aligment. The seizing bearing might have caused it to jump a tooth/notch or two. From the extra drag due to the bearing failing
Thanks, man. It looks like I'm more or less fucked here. Honda wants 350 for a new one, and I had one on the motor I swapped this one out for. The motor my parents made me drop off at the wrecker two weeks ago.
killafred187
Mar 10, 2014 05:23 PM
DA9kid
Jun 30, 2011 06:22 AM
EK9ED
Oct 14, 2010 10:30 AM
xjun10rx
12
Aug 16, 2004 12:20 AM
