gsr clutch question
Old Nov 24, 2004 | 12:32 PM
Chris_Bye's Avatar
Default gsr clutch question
my clutch all of a sudden today felt really soft and easy to push in. It used to engage all the way at the end, now it engages in the very middle. Anyone have similar problems like this? any help is appreciated.
side notes: i have been beating on the car a little more than usual, since i went to the track, etc. The car is stock besides sr intake.
Old Nov 24, 2004 | 12:57 PM
Chris_Bye's Avatar
Default Re: gsr clutch question (Chris_Bye)
....anyone....
Old Nov 24, 2004 | 01:41 PM
EL Vap133's Avatar
How many miles does your current clutch have?
Old Nov 24, 2004 | 01:50 PM
.water's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris_Bye &raquo;</TD></TR><TR><TD CLASS="quote">my clutch all of a sudden today felt really soft and easy to push in. It used to engage all the way at the end, now it engages in the very middle. Anyone have similar problems like this? any help is appreciated.
side notes: i have been beating on the car a little more than usual, since i went to the track, etc. The car is stock besides sr intake.</TD></TR></TABLE>
hmm..same happening..but never engages in the very middle again..just frieaking high...
bleed change ur clutch fluid
Old Nov 24, 2004 | 02:14 PM
Chris_Bye's Avatar
Default Re: gsr clutch question (Bee8teenSee1)
i believe 85k are on the clutch.
Old Nov 24, 2004 | 02:38 PM
NeoGSR's Avatar
85k is getting up there.....might wanna start thinkin about a new clutch....ACT works for me
Old Nov 24, 2004 | 02:42 PM
Chris_Bye's Avatar
Default Re: gsr clutch question (NeoGSR)
hmm, new clutch, my old clutch lasted me till about 135k (da), but i didn't really drive it too hard. I don't drive this car hard either, this weird problem just started happening today.
Old Nov 24, 2004 | 02:43 PM
rovigian's Avatar
Stock clutches are easy to heat glaze from being rough on them, and will feel really weak afterwards. At 85k sounds like it's a good time for a new one anyways. Look at where you clutch pedal pumps into (master cylinder) also and make sure there is nothing leaking.
Old Nov 24, 2004 | 02:44 PM
Chris_Bye's Avatar
Default Re: gsr clutch question (rovigian)
maybe i will do a new clutch soon then. How much is installation usually on a clutch?
Old Nov 24, 2004 | 03:47 PM
Chris_Bye's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rovigian &raquo;</TD></TR><TR><TD CLASS="quote">Stock clutches are easy to heat glaze from being rough on them, and will feel really weak afterwards. At 85k sounds like it's a good time for a new one anyways. Look at where you clutch pedal pumps into (master cylinder) also and make sure there is nothing leaking.</TD></TR></TABLE>
i think it is the master cylinder leaking because i just took another drive and it is just getting worse. The clutch pedal now almost doesn't engage at all, it has to be all the way to the floor touching the carpet. I am unsure where the reservoir is for the clutch fluid, but it must be leaking.
Can someone send me a picture of where the master cylinder for the clutch fluid is asap, i need to drive this car.
Old Nov 24, 2004 | 03:55 PM
HONDA RR's Avatar
I RECOMMEND YOU TO REPLACE YOUR CLUTCH.
Old Nov 24, 2004 | 04:14 PM
Chris_Bye's Avatar
Default Re: gsr clutch question (MITSUBA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITSUBA &raquo;</TD></TR><TR><TD CLASS="quote">I RECOMMEND YOU TO REPLACE YOUR CLUTCH. </TD></TR></TABLE>
I DON'T CARE WHAT YOU RECOMMEND, THE CLUTCH IS FINE, IT IS THE MASTER CYLINDER, AND TAKE YOUR CAPS LOCK OFF N00B!
Old Nov 24, 2004 | 04:28 PM
Chris_Bye's Avatar
c'mon people, i really need to fill this thing up with some hydro fluid quick!
onefstek
Jun 8, 2006 01:18 PM
BigC-ivic
Apr 23, 2005 07:34 AM
xkpjokerx
15
Dec 1, 2004 02:39 AM
typeee
Oct 2, 2004 08:15 PM
AspectIndustries
Jan 5, 2004 07:49 AM
