obd1 wiring question - pin B8-PSSW???
Old Nov 24, 2004 | 11:03 AM
BIGBLOCKEK's Avatar
Botched thread poll
Default obd1 wiring question - pin B8-PSSW???
i have almost all of my wiring taken care of, with the exception of pin b8, i cheked the list and its PSSW. what is this? it says it also should be a brown/red wire. on my harness it is blue wire and its just haging loose.
Old Nov 24, 2004 | 01:25 PM
Turbogixxer's Avatar
Default Re: obd1 wiring question - pin B8-PSSW??? (BIGBLOCKEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by copied from the link in my sig &raquo;</TD></TR><TR><TD CLASS="quote">B8-PSPSW PSP switch Red/Green (brown/red for civic), Power steering oil pressure switch, 0V KOEO; Battery Voltage KOER While slowly turning steering wheel</TD></TR></TABLE>
PSP switch is a load detector. When you turn the wheel (with power steering, of course) it sends battery voltage to the ECU as a signal.
Why do you need this?
The ECU has to add more fuel/air because of the load that power steering pump will take. If it does not do this, the idle RPM will lower (or even stop the engine) because of the load of the power steering pump working.
why does it not need it at higher RPM?
The engine run lean at idle so that little loads make a big difference.
If you have wire up the switch,
one wire goes to B8
other one goes to ground
OF course, if you do not have power steering, disregard this.
Modified by turbogixxer at 5:50 PM 11/24/2004
Old Nov 25, 2004 | 02:31 PM
BIGBLOCKEK's Avatar
Botched thread poll
Default Re: obd1 wiring question - pin B8-PSSW??? (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by turbogixxer at 5:50 PM 11/24/2004</TD></TR></TABLE>
awsome! thanks alot im set
Old Nov 27, 2006 | 07:06 PM
clayne's Avatar
Default Re: obd1 wiring question - pin B8-PSSW??? (Turbogixxer)
https://honda-tech.com/zerothread?id=1822326
PaRRoWMaN
26
Aug 16, 2019 10:40 AM
ODDeyeC
Dec 15, 2009 05:26 AM
elizzabizza
Honda Civic (2001 - 2005)
May 28, 2007 11:53 AM
Kouki-EK9
Oct 21, 2005 07:30 PM
